Home > Puma (Tdci) > Puma 2L2 2016 engine broken !? Bet are open |
Vmesch Member Since: 06 Dec 2014 Location: Antwerp - Lier Posts: 47 |
too low engine oil level or... completely dried up engine???
It sounds as a lack of lubrication to me and the high friction could cause a rapid slowdown in your engine's rpm. Did you notice any smoke from the exhaust or any particular smell? puma 2.2 MY2013 [:O]===[O:] |
25th Jan 2016 12:19pm |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 559 |
Could it be oil pump failure? there has been a recall.
Kind Regards Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
25th Jan 2016 1:26pm |
Could be oil pump but you would have expected the production line to to get the updated parts as well, especially on such a new vehicle.
25th Jan 2016 3:43pm |
arno Member Since: 24 Jul 2015 Location: Lausanne Posts: 31 |
No no smoke, no weird smell I saw them around noon and explain to them again how it happen, the event before, and the where suppose to call my at the end of the day to tell me what happen, but no news since. |
25th Jan 2016 7:33pm |
Bumpymike Member Since: 18 Nov 2015 Location: cheshire Posts: 71 |
having run a few transit vans over the years we have suffered cam carriers breaking on the TDCI engine.
So basically the valves don't get operated which could cause engine to stop quickly. |
25th Jan 2016 9:24pm |
Jukathy Member Since: 25 Jan 2015 Location: Berlin Posts: 170 |
Well, w / 2000 km on the clock...
Everything possible. Check thzz w/ JLR |
26th Jan 2016 5:30pm |
After 3 days in the shop, they didn't find the problem yet.
The engine won't start anymore, they think about the diesel high pressure pomp, but they are not even sure about it. So car is blocked for 10 days, the time it take to have a new pomp, then they gona change it. After that if it's not working they start to open the engine and look into it. I love my Defender unbreakable car !!! Rhaaaa !! |
28th Jan 2016 5:23pm |
Is it at Emil Frey in Crissier? You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
28th Jan 2016 5:36pm |
yes in contact with Landrover Switzerland and Solihull !!
28th Jan 2016 5:37pm |
It is terrible that this happens to you, but Emil Frey most certainly will properly sort it out, even if it would mean a new engine. You never actually own a Defender. You merely look after it for the next generation.
28th Jan 2016 5:41pm |
So finally I got my car back, 7 weeks !!
They change the engine HP pump, the high pressure valve, the ECU, a few join, and the winner is: Broken Injector It was working well in a electronic point of view, so always ok when you do a test but it was mechanically broken, and gasoline where just liking in the engine, and sometime 'boom' an explosion but not at the right time ! (that was the mechanical noise). So they replace it, clean all the exhaust pipe. But now we are keeping a close eyes to the engine to be sure they is no more trouble on it. |
12th Mar 2016 1:04pm |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 |
Good to hear your problem is solved. Your dealer, or JLR owe you one now. So you should get good service in future.
I wish you a trouble free run from here! 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTs, Recaro CSs, anorak, wellingtons |
12th Mar 2016 1:26pm |
