Home > Off Topic > Rivnut tool recommendation
stricko
Hi
Can someone recommend a good (and cheap) rivnut tool.
I need to replace my front mudguard brackets as they both rotted through within about 500 miles of each other.
I could do with getting one for the weekend if possible.
Cheers ---------------------------------------------------------------
Post #494698 21st Jan 2016 10:56am
jimbob7
Replaced the rears with stainless nut and bolt (difficult,lol).I assume the same is not possible for the front??Also,really needed this weekend????Could be a good job for warmer weather. Pov.spec,ftw. 2006, 110,TD5.
Post #494707 21st Jan 2016 11:15am
Skeggy 90
England 2011 Defender 130 Puma 2.4 SW Bali Blue
You don't need a tool, I just use a long bolt a few washers and a nut, works a treat, look on YouTube for how to do ir. The cheaper tools have a tendency of ripping the treads out if your not careful. 90 300 TDI SW (sold)
130 TD5 Utility (Foley SV) (sold)
110 TD5 Hardtop (sold)
110 TDCI Utility (sold)
1st Edition Range Rover Sport Supercharged
Velar P380 HSE
Discovery 1 V8 auto
Puma 130 Double Cab (sold)
R35 GTR
Defender 110 300 TDI CSW (sold)
2010 110 XS Utility
Post #494708 21st Jan 2016 11:16am
stricko
Cheers Skeggy
I have had a look and will give that a go.
Next question - any idea what size rivnut I should get ? ---------------------------------------------------------------
Post #494735 21st Jan 2016 11:47am
Skeggy 90
6mm thread is for a 10mm headed bolt
8mm thread is for a 13 mm headed bolt
There is a choice of aluminium or steel rivnuts,
What size are the original mounting bolts, I would get the same if you can get away with it if not go one size bigger 90 300 TDI SW (sold)
Velar P380 HSE
Discovery 1 V8 auto
R35 GTR
2010 110 XS Utility
Post #494740 21st Jan 2016 11:55am
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
Possibly doesn't fit the 'cheap' description but the Memfast tool is very good
http://www.memfast.co.uk/cli/MEM001/PDF/RN...Review.pdf
Post #495241 22nd Jan 2016 5:45pm
LRmud
Scotland 1989 Defender 90 300 Tdi HT Baltic Blue
I just bought this from ebay and it works a treat. Very cheap AND effective.
http://www.ebay.co.uk/itm/121854739388
I've also got an M6, M8 and M10 - all good.
Remember to put a dab of grease on the parts before use. Thumbs Up --------------------------------------------------------------------------------------------------
1989 Defender 90
Toyota Aygo & Honda FR-V
Post #495243 22nd Jan 2016 5:53pm
