Home > Maintenance & Modifications > Mantec RAI Mounting
Page 2 of 2 <12
There are two drain holes in the airbox, one for the water separator and one for the box itself. The latter runs through the centre of the front inboard mounting prong.
Post #494862 21st Jan 2016 5:39pm
Cheshire110
Thanks for the info guys 👍 Cheers, David
Post #494875 21st Jan 2016 6:37pm
Blackwolf - The water separator one I thought was part of the joint between the airbox and ducting?
I seem to remember some holes in the outer piping of which little 'tangs' on the separator fitted into to keep it in place.
I can't quite remember the exact locations though.
The drain hole(s) you mention I assume are not these?
Post #494879 21st Jan 2016 7:07pm
HardCharger
Hi All!
Asides from the nugget kit, will the airflow kit II from entreq work with the Mantec RAIs as well? I kinda of find the price for their snorkel a bit too high though I'm sure I can do the budget for it.
I was considering these possible combinations:
1.) All Entreq kit
2.) Mantec mushroom head RAI and nugget kit
3.) Mantec mushroom head RAI and Entreq Airflow Kit II
Looking forward to hearing your thoughts on the matter.
Post #497665 29th Jan 2016 2:31am
Page 2 of 2 <12
