![]() | Home > Maintenance & Modifications > Mantec RAI Mounting |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2774 ![]() ![]() |
Thanks for the info guys 👍 Cheers, David
Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20751 ![]() ![]() |
Blackwolf - The water separator one I thought was part of the joint between the airbox and ducting?
I seem to remember some holes in the outer piping of which little 'tangs' on the separator fitted into to keep it in place. I can't quite remember the exact locations though. The drain hole(s) you mention I assume are not these? |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 757 ![]() ![]() ![]() |
Hi All!
Asides from the nugget kit, will the airflow kit II from entreq work with the Mantec RAIs as well? I kinda of find the price for their snorkel a bit too high though I'm sure I can do the budget for it. I was considering these possible combinations: 1.) All Entreq kit 2.) Mantec mushroom head RAI and nugget kit 3.) Mantec mushroom head RAI and Entreq Airflow Kit II Looking forward to hearing your thoughts on the matter. |
