Home > In Car Electronics > Nanocom
Rob00
Wales 2007 Defender 110 Puma 2.4 USW Java Black
Nanocom
I am thinking in investing in a nanocom next week due to issues i am currently having and similar ones i have had previously with alrm/imobiliser.
I am afer some feedback on them if possible please?
Post #492715 15th Jan 2016 7:17pm
dumptruckface
England 2012 Defender 110 Puma 2.2 XS DCPU Orkney Grey
i cant help with your decision making but im interested in the nanocom and if its the kind of tool we should all have in our tool box? my local LR dealer are charging 108 per hour for any works so the nanocom could potentially pay for itself over a couple of years!
also is there anything extra special that can be unlocked, upgraded or activated at all with the nanocom? just thinking of any other plus points that would help sell itself Smile
Someone must have some input on this?
Post #495094 22nd Jan 2016 11:31am
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
I have a Nanocom Evo that I initially purchased for my MY2009 2.4 Puma 90.
I haven't used it much as my Puma is absolutely faultless (touch wood! Thumbs Up ), but the Nanocom gives access to a lot of functions, including the immobilizer. The recent SW updates (1.30) also include injector coding and learning as well (although I haven't tried, as I had no need).
But then I just bought a MY2003 Disco TD5 so I purchased the additional unlock codes for the TD5 and Disco 2 functions, and that helped me clear/investigate some ABS issues already!
So. IMHO, the Nanocom is great especially if you have more than one vehicle supported, that proves to be invaluable.
Post #495149 22nd Jan 2016 1:39pm
Cupboard
When I was deciding a few months ago, I went for the GAP Diagnostics IID Tool. I'm happy with it, but the Nanocom is good too.
Advantage of the Nanocom is with older Land Rovers.
Post #495154 22nd Jan 2016 1:54pm
Snowy90
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Fuji White
Ive been thinking about this as have a Defender but also an aging! L322 Range Rover, is it easy to switch between cars and od4n was it expensive for the other unlock code's
Is it as simple as downloading the codes for your cars and then just plugging it in?
Post #495176 22nd Jan 2016 3:14pm
o4dn
These are unlock codes, you don't even have to download anything at all, you already have the software, the unlock codes just give you access to the functionality already on your Nanocom.
As for price, for example, the unlock code for the RR L322 is listed at 168.14 on their web page:
http://www.nanocom-diagnostics.com/shop/browse
Or you could do the other way around, purchase the Nanocom for the L322 and buy the unlock codes for the Defender Puma which is listed at 41.40 (probably the same price in the end as the Nanocom with coverage for the L322 is more expensive than the one for the Puma in the first place).
Also, I'd suggest to get in touch with them to make sure you can use the same OBD2 lead for both cars.
(Disclaimer, I do not work for Blackbox Solutions nor have any business relationship with them!) “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #495189 22nd Jan 2016 3:48pm
o4dn
Actually, I reckon you may need 2 different leads for the Puma and the L322 (Blue OBD2 lead for the Puma and VCI 4 CAN BUS cable for the L322), so that'd add up to the price. “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Post #495194 22nd Jan 2016 4:00pm
