Home > Technical > 1995 300tdi 110 weird starting issue. |
24heuer Member Since: 21 Jul 2015 Location: Edinburgh Posts: 167 |
@AJC
Thanks, Good thing is it seems everyone believes it's air getting in somewhere. Hopefully with a bit of daylight and a dry weekend I should be able to investigate further. Thing I really don't understand is that before all this started it was leaking fuel from the pipe union on the sender and yet still started every time on the button. That's the reason I swapped the sender out in the first place last summer. I'm thinking if fuel was leaking out at that point why didn't I have difficulties starting it then? I'm confused Cheers, Andy... Edinburgh, Scotland http://24heuer.com |
6th Jan 2016 6:39pm |
hi JFH, thanks, checked and rechecked yesterday - they all seem fine and the banjo bolts are all tight with no visible leaks.
I did also retighten the fuel pipe to sender union a fraction of a turn. I'm worried about overtightening this though in case I break the plastic pipe on the sender again. Cheers, Andy... Edinburgh, Scotland http://24heuer.com |
11th Jan 2016 9:55am |
Ok, I slackened and retighted the banjos on the spill rail and also the fuel pipe union on the sender.
Starting on the 1st turn now so I'm hoping that's it. Thanks all for the suggestions. Cheers, Andy... Edinburgh, Scotland http://24heuer.com |
18th Jan 2016 1:57pm |
