![]() | Home > Puma (Tdci) > VDO DTCO 1381 Tachograph |
DaftOldGit Member Since: 20 Sep 2015 Location: London Posts: 52 ![]() ![]() |
My motor had this tacho fitted when i bought it. I have no need of it, but when I unplug it the speedo and odometer stop working.
Does anyone have experience of these units? Is it just wired in series with the speedo somehow, and i can just short a couple of wires to restore operation, or is there more to it than that? |
Is it not possible to follow the loom back ?
https://www.defender2.net/gallery/albums/u...rchive.pdf |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 561 ![]() ![]() ![]() |
Those instructions are the old way of installing a digital tachograph, the short speedo cable didn't prove reliable. If it's an early puma it will be like this. If it's newer follow the loom back there should be a yellow box which is a M1N1 adaptor this will have a +30 and +15 power supplies also the speedo signal will feed into this, you will need to join the speed signal wires back together.
Regards Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
Thanks for your replies.
Its a 2007 Puma, but i dont know when the tacho was fitted. I'll have a look later and see which way it's been done. I'm guessing that if its the older style then i just need to fit a new speed sensor and reconnect the original cable, then just unplug the tacho and leave the plugs as they are? |
willyj Member Since: 23 Oct 2009 Location: Carmarthenshire Posts: 195 ![]() ![]() ![]() |
Hi DaftOldGit
Just found this thread. I have the same tacho unit and I was wondering if you might still have it kicking around as I’m after the cable? Thanks Wil |
That was eight years ago!
I don’t even have the motor any more. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17619 ![]() ![]() ![]() |
