![]() | Home > Technical > IPF Headlights not working on dipped beam |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
If you're getting odd behaviour as with your CD player, it would suggest to me that there might be something as simple as an earthing problem. Check the earths for proper contacts.
Sensible educated answers i'm sure will follow shortly. Welcome to Defender2, PM1 ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20591 ![]() ![]() |
As 110SEB says above and also personally I would check your battery terminals are tight and making good contact positive as well as neutral. Hope it gets sorted soon
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
Sounds like a frazzled switch/stalk to me. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
PM 1 Member Since: 17 Oct 2010 Location: Northumberland Posts: 16 ![]() ![]() |
Thanks for the quick responses.
I am confident the battery terminals are good and I have tried using a different switch but had the same trouble. Where do the headlights Earth too? Do the dipped lights have any relation to the main beam/flash switch as this has evidence of where I think that switch overheats, but is this enough to prevent dipped lights working? I'm confused...Ill check the Earth tonight if you can help me identify where to look. Thanks again. |
For anyones future reference....the problem was diagnosed as a faulty main beam/indicator stalk.
A quick trial of a new stalk fixed the problem straight away. It appears that there is a common +ve that runs through both switches and if that fails, you lose light Just in time for the dark nights. Thanks for everyones help. |
