Home > Puma (Tdci) > forced DPF regen - available from Nanocom / BAS diagnostics?
Page 2 of 2 <12
flydive
Switzerland 2015 Defender 90 Puma 2.2 Heritage Edition SW Grasmere Green
Well, for me would be ok to be able to force regen at slower speed/RPM than a normal
Post #520934 4th Apr 2016 8:02pm
Cheshire110
don't many cars have a forced regen button?
Dads land cruiser V8 has a "fart" button Cheers, David
Post #521119 5th Apr 2016 1:07pm
Jukathy
2012 Defender 110 Puma 2.2 SW Keswick Green
Blackbox include DPF regen and DPF reset in their latest firmware. Thumbs Up
Post #524330 15th Apr 2016 9:53pm
GregK Myanmar
2010 Defender 110 Puma 2.4 SW Stornoway Grey
In topix there is a Special Service Bulletin entitled
SSM64357 - Defender DPF Regeneration using Low Range
Bulletins>Special Service Messages >Engine
Does anyone here have access to TOPIX to be able to know what it says?
Post #553870 5th Aug 2016 1:22pm
GregK Myanmar
Here is the info on how to do a manual regeneration.
Issue:
DPF Regeneration using Low Range.
Action:
It is possible to regenerate the Diesel Particulate Filter (DPF) in low range. This can be done by carrying out the following drive cycle. 1) Drive the vehicle in 3rd gear low range.
2) To ensure optimum regeneration of the DPF, the engine speed must be maintained at between 3000-4000rpm.
3) Drive the vehicle for a total of 10 minutes to the condition specified in points 1 and 2. During the drive cycle the amber DPF lamp will extinguish, if this happens before 10 minutes has elapsed please continue to drive the vehicle until the full 10 minutes has been achieved to ensure full regeneration of the DPF. 2010 Defender 110 Puma 2.4 TDCI.
Post #555749 13th Aug 2016 3:20pm
flydive
Very good info.
Thank you
Thumbs Up
Post #555793 13th Aug 2016 7:12pm
Jukathy
Yap, good info for the amber light - but forced DPF regen extinguishes the r e d DPF light !
And you'll need a Nanocom or a retailer's SDD kit ... Whistle
Post #555810 13th Aug 2016 8:54pm
Page 2 of 2 <12
