Home > Puma (Tdci) > forced DPF regen - available from Nanocom / BAS diagnostics? |
flydive Member Since: 27 Aug 2015 Location: Lugano Posts: 290 |
Well, for me would be ok to be able to force regen at slower speed/RPM than a normal
4th Apr 2016 7:02pm |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2751 |
don't many cars have a forced regen button?
Dads land cruiser V8 has a "fart" button Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
5th Apr 2016 12:07pm |
Jukathy Member Since: 25 Jan 2015 Location: Berlin Posts: 170 |
Blackbox include DPF regen and DPF reset in their latest firmware.
15th Apr 2016 8:53pm |
GregK Myanmar Member Since: 18 May 2016 Location: Yangon Myanmar Posts: 22 |
Here is the info on how to do a manual regeneration.
Issue: DPF Regeneration using Low Range. Action: It is possible to regenerate the Diesel Particulate Filter (DPF) in low range. This can be done by carrying out the following drive cycle. 1) Drive the vehicle in 3rd gear low range. 2) To ensure optimum regeneration of the DPF, the engine speed must be maintained at between 3000-4000rpm. 3) Drive the vehicle for a total of 10 minutes to the condition specified in points 1 and 2. During the drive cycle the amber DPF lamp will extinguish, if this happens before 10 minutes has elapsed please continue to drive the vehicle until the full 10 minutes has been achieved to ensure full regeneration of the DPF. 2010 Defender 110 Puma 2.4 TDCI. |
13th Aug 2016 2:20pm |
Very good info.
Thank you |
13th Aug 2016 6:12pm |
Yap, good info for the amber light - but forced DPF regen extinguishes the r e d DPF light !
And you'll need a Nanocom or a retailer's SDD kit ... |
13th Aug 2016 7:54pm |
