Home > Puma (Tdci) > Simple Question
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Simple Question
Having fitted Diff Guards - Steering Guard and some Paddock Bumperettes to my 90 I'm thinking of a snorkel.
How do you get the Plastic Air Intake Grill OFF?
Which Snorkel would members recommend? NOT for really deep water - more to cope with water splash than deep wading. We do get some flooded roads around here and it has been known for oncoming inconsiderate/stupid drivers to speed through sending a great wave over the car and of course the Air Intake is on the drivers side right in the path of the wave.
Any help much appreciated. Bow down
Post #42737 16th Oct 2010 2:59pm
AndrewS
Try the search button loads of info Thumbs Up 130's have feeling's as well you know Smile
Post #42740 16th Oct 2010 3:44pm
WelshGas
Cannot find anything about the Air Intake Grill.
There doesn't seem to be any definite decision with regards to snorkels. Seems to be mainly down to aesthetic taste. As they all seem to do what's on the tin.
Just as an aside. I had searched the forums but the search engine is not that intuitive.
Post #42794 17th Oct 2010 10:50am
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
AndrewS has an excellent guide in his gallery to fitting the Mantec Raised Air Intake. The first picture of which should answer your question perfectly (hopefully Andrew won't mind me linking it).
 Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #42799 17th Oct 2010 11:48am
warren
England 2009 Defender 90 Puma 2.4 HT Santorini Black
I just touched mine and it fell off!
Post #42803 17th Oct 2010 12:49pm
RED-DOT
8 small (2mm) plastic pins which break off if you are too rough with them (like i was). 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #42805 17th Oct 2010 12:52pm
WelshGas
Thank you MrFlips. Just what I wanted.
Post #42806 17th Oct 2010 1:56pm
alantd
There's no real consensus around which RAI is best. Most people either have the mantec plastic jobby or safari. Mantec is cheaper and easier to fit but safari is more water tight (it's components stretch further back towards the air box).
Looks are purely subjective. I have the mantec and am very pleased with it - although watch for the self tapping screws on the A pillar coming loose over time (applies to both brands).
Both will do what you suggest you need it for (very sensible). If you want to go deep water wading, buy a 200tdi. One that started out as a 2.4 TDCi 110 XS
Post #43090 19th Oct 2010 9:49pm
WelshGas
Thanks alantd. saw a 90 with the Mantec up close yesterday. Think it will do the job nicely.
I can feel a note to Father Christmas coming on.
Post #43097 20th Oct 2010 5:47am
mse
Long noise pliers in the centre and pull out removes it easy.
Safari is the only snorkel for me! Mike
Post #43137 20th Oct 2010 5:01pm
