![]() | Home > Defender Celebration Series & Classic Works > Blue Fluid Leak on the Heritage |
Avion8 Member Since: 26 Jan 2015 Location: Perth Posts: 281 ![]() ![]() ![]() |
Hi Ian,
Here is where my leak was evident. I might add that it never dripped onto the ground & once wiped off has not return: [URL=] ![]() I'm still not exactly sure of the exact source, and as mentioned once cleaned off has not returned. It is fairly viscous & similar colour to Hylomar. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Interesting, thanks very much.
This is what Land Rover supplied me for lubricating the shaft splines, just a Weicon grease. It's odd as I have never found this blue fluid on a defender. We have a 2015 double cab, which I did drop the box out of to grease the splines. It was dry, unless LR have finally listened, and greased the very last few thousand in production? ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
Actually, now looking at your photos again, I wonder if those bolts that hold the black bracket under the case have had a dosing of locktite?
It sure looks like that to me? I would wind one out to see..... ![]() Wanted, Forward Control Anything considered. |
GreenHue Member Since: 28 Aug 2015 Location: Derbyshire Posts: 23 ![]() ![]() |
Good idea to bring Ryan at Land Rover into the loop
Does anyone know how to do that? Wanted a Defender for 30 years - now own the best - A Heritage 2015 90 SW Heritage 2014 RR Sport 2014 RR Evoke |
Raise a post on his section of the forum - link to here to see the various photos or repost them there...
toby9946 Member Since: 23 Sep 2015 Location: Hampshire/London Posts: 96 ![]() ![]() ![]() |
As I posted early in the topic I had this mysterious fluid on my Landmark, noticed it on about day two. Seems a few months on still no sign of it having returned luckily but would still be comforting to know what it is!! -2015 Defender 90 XS Landmark-
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 ![]() ![]() |
If that's the case I'd suggest it's either a locking compound or sealant that's used in the manufacture of the vehicle, perhaps slightly over-zealously applied and during initial use, warms up, overspills and then settles down as it should be.
If it doesn't continue to leak, I would leave well alone. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6328 ![]() ![]() ![]() |
my understanding is the latest models had a new spec grease which it would be nice to think will resolve the worn spline issue otherwise I best starting saving for my 5th shaft which should be needed at about 110k miles.
the grey grease shown is from what I believe what my last one was coated with. I believe the part number for the grease is LR078521 ? sorry if this has been said elsewhere but I think there's a mis-understanding to suggest shafts / splines haven't been greased as my last one (and previous ones) have all looked like there's been no grease ever but I know full well that they were greased? Has anyone experienced a 'blue' one having failed? ![]() |
