Home > Defender Celebration Series & Classic Works > Blue Fluid Leak on the Heritage
Page 3 of 3 <123
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
So if it's oil, is it leaking from the transfer box itself?
Can't see them lubricating the shaft with oil, as it wouldn't stay where it's supposed to be?
The cup and spline are not sealed for fluid.
It would be interesting to get to the bottom of this. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #489504 7th Jan 2016 9:13am
Avion8
Australia 2015 Defender 90 Puma 2.2 Heritage Edition SW Grasmere Green
Hi Ian,
Here is where my leak was evident. I might add that it never dripped onto the ground & once wiped off has not return:
[URL=][/URL]
I'm still not exactly sure of the exact source, and as mentioned once cleaned off has not returned. It is fairly viscous & similar colour to Hylomar.
Post #489513 7th Jan 2016 9:43am
ian series 1
Interesting, thanks very much.
This is what Land Rover supplied me for lubricating the shaft splines, just a Weicon grease.
It's odd as I have never found this blue fluid on a defender.
We have a 2015 double cab, which I did drop the box out of to grease the splines.
It was dry, unless LR have finally listened, and greased the very last few thousand in production?
 80" 80" 86" 88" 90"
Post #489546 7th Jan 2016 11:15am
ian series 1
Actually, now looking at your photos again, I wonder if those bolts that hold the black bracket under the case have had a dosing of locktite?
It sure looks like that to me?
I would wind one out to see..... Whistle 80" 80" 86" 88" 90"
Post #489547 7th Jan 2016 11:18am
GreenHue
Good idea to bring Ryan at Land Rover into the loop
Does anyone know how to do that? Wanted a Defender for 30 years - now own the best - A Heritage
2015 90 SW Heritage
2014 RR Sport
2014 RR Evoke
Post #489784 7th Jan 2016 10:15pm
Raise a post on his section of the forum - link to here to see the various photos or repost them there...
Post #489788 7th Jan 2016 10:23pm
toby9946
United Kingdom 2015 Defender 90 Puma 2.2 Landmark LE Corris Grey
As I posted early in the topic I had this mysterious fluid on my Landmark, noticed it on about day two. Seems a few months on still no sign of it having returned luckily but would still be comforting to know what it is!! -2015 Defender 90 XS Landmark-
Post #489872 8th Jan 2016 9:38am
RRUK
If that's the case I'd suggest it's either a locking compound or sealant that's used in the manufacture of the vehicle, perhaps slightly over-zealously applied and during initial use, warms up, overspills and then settles down as it should be.
If it doesn't continue to leak, I would leave well alone. 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #489874 8th Jan 2016 9:41am
Caterham
my understanding is the latest models had a new spec grease which it would be nice to think will resolve the worn spline issue otherwise I best starting saving for my 5th shaft which should be needed at about 110k miles.
the grey grease shown is from what I believe what my last one was coated with.
I believe the part number for the grease is LR078521 ?
sorry if this has been said elsewhere but I think there's a mis-understanding to suggest shafts / splines haven't been greased as my last one (and previous ones) have all looked like there's been no grease ever but I know full well that they were greased?
Has anyone experienced a 'blue' one having failed?
Thumbs Up
Post #611170 21st Mar 2017 5:16pm
Page 3 of 3 <123
