Home > Maintenance & Modifications > Aftermarket External Temperature Gauge?
Riccarton
Scotland 2012 Defender 90 Puma 2.2 HT Zambezi Silver
Dear Collective,
Has anyone fitted or can anyone recommend an aftermarket external temperature gauge that I can add to my 90 TDCi?
Ideally I was hoping for a 12v jobby with literally just the temperature display but all the ones I've managed to find have internal batteries and / or go the multifunction route incorporating clock etc.
Any recommendations greatfully recieved.
Thanks.
Post #482901 16th Dec 2015 7:45pm
ericvv
Post #482914 16th Dec 2015 8:18pm
Litch
If you have a flat panel to fit it into then I recommend one of these eBay specials, I have had mine for 3-years now and can't fault it.
They cost under £10, 12V powered, totally accurate, reliable and come with a choice of probe lengths.
Just do a search for 12V temperature gauge and you will see several suppliers (China, Hong Kong etc).
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  ONE LIFE, GET IT!
Post #482916 16th Dec 2015 8:24pm
LR90XS2011
alternatively buy a scan gauge that will tell you loads of info including ambient air temperature DEFENDER 90 TDCI XS,
Post #482920 16th Dec 2015 8:28pm
camelman
Buy the torque app for £3 and a Bluetooth obdii sender for £10 and you can have as many gauges as you like on your phone / tablet screen fed from the ecu
heres an example screenshot
Post #482923 16th Dec 2015 8:32pm
Riccarton
Thanks Guys Bow down
Scan Gauge looks well cool but a tad over complex for what I'm after.
I really like the inset ones and the price is great - the VDO one is in keeping with the car I guess and has the right name on it so well worth a coat of looking at - just not sure analogue is the way to go for this. Hmmm decisions decisions Big Cry
Plenty of food for thought so thanks!
Post #482956 16th Dec 2015 9:37pm
Riccarton
Wow Shocked
Forgive my ignorance but would my BAS tool do a similar thing?
As a pretend farmer it is the law that I have to gawp over field walls whilst travelling - if I had all that info to hand as well I reckon oncoming traffic could be in for a shock Laughing
Post #482959 16th Dec 2015 9:41pm
camelman
Riccarton, just tried it with my BAS tool and the Torque app doesn't recognise it.
You do have the LIVE VIEW function on the BAS app although I prefer the layout flexibility of the Torque app as you can set up 5 different screens configured with which ever gauges at whatever size you fancy.
Horse for courses and all that Smile
Post #483091 17th Dec 2015 1:14pm
dgardel
Italy
http://www.defender2.net/forum/topic5492.h...heque+temp Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #483095 17th Dec 2015 1:45pm
lohr500
Hi Camelman, this looks like a really interesting solution. Do you know if any of the cheap OBDii Bluetooth senders on eBay will do? Or do you have a specific model that you use? They seem to start at as little as £4. But I don't want to buy a real cheapo if they are useless!! Thanks
Post #483170 17th Dec 2015 7:53pm
Roy5695
United Kingdom 2011 Defender 110 Puma 2.2 XS DCPU Indus Silver
Ill through another in there, i have the ultragauge unit in mine, very good at what it doen and also reads fault codes! Worth a look!
Post #483272 18th Dec 2015 3:20am
Poohbore
Does anyone know the Apple name of the app ?
I've had a look but can't find the one above Scratching a 20 year itch that hopefully will be cured when I buy one...
Post #483280 18th Dec 2015 6:28am
camelman
Just to let you know, torque also reads faults codes and lets you reset them Smile
Not sure it is available on ios but there is a similar one called 'Dashcommand'.
I think there have been problems with some of the really really cheap sender units on ebay, mine cost around £9 and is marked 'ProScan', had it a couple of years now with no problem.
As long as you buy from a uk seller, you can return it if it doesn't work anyway.
Post #483296 18th Dec 2015 9:24am
redline
Switzerland
I'm using the Torque App (Android) with a Scantool MX OBD Bluetooth transmitter. Works perfectly and the setup is transportable to other vehicles (you just setup another profile). It can display any data that is transmitted on the CAN-bus.
The Scantool is a quality transmitter, but probably overpriced. A friend picked up an unbranded on on E-bay for $5.99 and it works just as well.
Post #483994 20th Dec 2015 5:38pm
aled
I bought this: http://www.ebay.co.uk/itm/111688952857 for £7.95
Installed DashCommand from the app store onto my iPhone6, and it works fine, easy WiFi connection.
The fuse cover won't close with the sender unit plugged in, it will require a modification. The sender unit has a lot of flashing lights on it (red/blue) which is a bit fussy. Intake air temp shows up but no ambient air temp (don't know if this is related to my poverty spec HT or not)
Post #484171 21st Dec 2015 12:32pm
