![]() | Home > Maintenance & Modifications > Aftermarket External Temperature Gauge? |
Couple suggestion...
This from Mobilecenter http://www.defender2.net/forum/topic5492.html Or a VDO version (which I like, but not in lieu of the clock) http://www.defender2.net/forum/topic18663....temp+gauge Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 765 ![]() ![]() |
If you have a flat panel to fit it into then I recommend one of these eBay specials, I have had mine for 3-years now and can't fault it.
They cost under £10, 12V powered, totally accurate, reliable and come with a choice of probe lengths. Just do a search for 12V temperature gauge and you will see several suppliers (China, Hong Kong etc). [URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() [/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3654 ![]() ![]() ![]() |
alternatively buy a scan gauge that will tell you loads of info including ambient air temperature DEFENDER 90 TDCI XS,
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3386 ![]() ![]() |
Buy the torque app for £3 and a Bluetooth obdii sender for £10 and you can have as many gauges as you like on your phone / tablet screen fed from the ecu
heres an example screenshot ![]() Click image to enlarge ![]() |
Riccarton Member Since: 10 Aug 2015 Location: Gods' Own Country Posts: 280 ![]() ![]() ![]() |
Thanks Guys
![]() Scan Gauge looks well cool but a tad over complex for what I'm after. I really like the inset ones and the price is great - the VDO one is in keeping with the car I guess and has the right name on it so well worth a coat of looking at - just not sure analogue is the way to go for this. Hmmm decisions decisions ![]() Plenty of food for thought so thanks! |
Wow ![]() Forgive my ignorance but would my BAS tool do a similar thing? As a pretend farmer it is the law that I have to gawp over field walls whilst travelling - if I had all that info to hand as well I reckon oncoming traffic could be in for a shock ![]() |
Riccarton, just tried it with my BAS tool and the Torque app doesn't recognise it.
You do have the LIVE VIEW function on the BAS app although I prefer the layout flexibility of the Torque app as you can set up 5 different screens configured with which ever gauges at whatever size you fancy. Horse for courses and all that ![]() ![]() |
http://www.defender2.net/forum/topic5492.h...heque+temp Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1330 ![]() ![]() ![]() |
Hi Camelman, this looks like a really interesting solution. Do you know if any of the cheap OBDii Bluetooth senders on eBay will do? Or do you have a specific model that you use? They seem to start at as little as £4. But I don't want to buy a real cheapo if they are useless!! Thanks |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
Ill through another in there, i have the ultragauge unit in mine, very good at what it doen and also reads fault codes! Worth a look!
Poohbore Member Since: 10 Nov 2012 Location: gwent Posts: 15 ![]() |
Does anyone know the Apple name of the app ?
I've had a look but can't find the one above Scratching a 20 year itch that hopefully will be cured when I buy one... |
Just to let you know, torque also reads faults codes and lets you reset them
![]() Not sure it is available on ios but there is a similar one called 'Dashcommand'. I think there have been problems with some of the really really cheap sender units on ebay, mine cost around £9 and is marked 'ProScan', had it a couple of years now with no problem. As long as you buy from a uk seller, you can return it if it doesn't work anyway. ![]() |
redline Member Since: 28 Jun 2015 Location: Mountains and Lakes Posts: 221 ![]() ![]() |
I'm using the Torque App (Android) with a Scantool MX OBD Bluetooth transmitter. Works perfectly and the setup is transportable to other vehicles (you just setup another profile). It can display any data that is transmitted on the CAN-bus.
The Scantool is a quality transmitter, but probably overpriced. A friend picked up an unbranded on on E-bay for $5.99 and it works just as well. |
aled Member Since: 02 Sep 2015 Location: UK Posts: 11 ![]() |
I bought this: http://www.ebay.co.uk/itm/111688952857 for £7.95 Installed DashCommand from the app store onto my iPhone6, and it works fine, easy WiFi connection. The fuse cover won't close with the sender unit plugged in, it will require a modification. The sender unit has a lot of flashing lights on it (red/blue) which is a bit fussy. Intake air temp shows up but no ambient air temp (don't know if this is related to my poverty spec HT or not) |
