Home > Puma (Tdci) > Anti-roll bars...? |
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 |
Anti roll bars do what they say on the tin Sir
Not sure about the 90 but the 110 xs has them as standard, makes it a lot better on road but slightly less axle articulation in the rough stuff. To be honest unless your doing hardcore stuff, i would spec em up You cannot teach stupid people to do clever things |
10th Oct 2010 7:22pm |
Amos Member Since: 10 Oct 2010 Location: Northern Ireland Posts: 38 |
Ok doing a bit of homework on the Internet, some people say the 90 comes with anti roll bars, and some say they don't.....!?!?
Does anyone know if they are standard on a new defender 90 xs.....? Many thanks |
10th Oct 2010 8:59pm |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
It all depends which wheels you get! If you have alloys (Boost or SVX style) they they come as standard.
As a 90 XS comes with alloys as standard then you will get ARB's as standard as well. Pete. |
10th Oct 2010 9:46pm |
Many thanks for clearing that up..... |
11th Oct 2010 6:25am |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 |
i've got the boost alloys but no anti role bars, and when we where doing some off roading with a land rover experience instructor he could not believe how much more articulation i was getting, as we where trying to get the two wheels of the ground cross axel pic, it will make a big difference at the extreame end of things and not a big problem when on the road in my opinion, but hay i'm a guy who would not pay for traction control so why listen to me
11th Oct 2010 9:10pm |
Are they factory fit? Did you buy your truck new? Could just be somebody fitted them at a later date and didnt fit the ARB's. Or it may be something to do with you having a 110 and HD suspension? Pete |
11th Oct 2010 10:40pm |
Allan Member Since: 09 Sep 2009 Location: Perth Posts: 166 |
I took them off on both the wife's TD5 90 and my Puma, much better ride on road and better suspension travel off road. Replaced the standard shocks with after market and both vehicles ride and handle very well.
Allan |
11th Oct 2010 11:22pm |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 545 |
I guess that could be related actually, anti-roll bars means less articulation, so the need for traction control to compensate. I was thinking of fitting anti-roll bars on mine (90 SW with standard steel wheels), but then realized that this may hinder the traction when off roading as I do not have ABS/TC fitted. There is an article on fitting anti-roll bars in LRM October issue, does not look like a hard job to do. Funny thing, he compares the end result with a standard 90 hard-top with steel wheels, and finds his considerably stiffer, but then I am not sure this one has anti-roll bars as standard as claimed in the article... |
12th Oct 2010 6:30am |
i did buy the truck new and spec'd up the county model as the xs was just outside my financial reach at the time, when i add'd the boost alloys i was told that as a factory fit extra they came with anti roll bars, but as you can imagine looking for the arb's when i picked up my first new land rover was not at the top of my list, once i noticed i was more than ok with the ride and the off road ability, i had also read about the articulation issue so never said a thing, good point about the HD suspention, i do seem to go through rear shock bushes very quickly, the top ones seem to last about 12 months before i can movment by hand on the top of the shock |
12th Oct 2010 9:16am |
Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 812 |
My 90 County (steel wheels) had no ARBs, but after test driving it (on the road) I had them fitted.
My last 90 had them, and driving around in the new one without them made me & the missus feel sea sick! I take the point that if you do a lot of off-roading, you may choose to put up with the sway on road though. And I have no idea what springs I have - it is a SW, so would guess HD? |
12th Oct 2010 9:52am |
the gamekeeper Member Since: 01 Jan 2010 Location: Surrey Posts: 96 |
This is information from the workshop manual 2007 on
Hope this helps Suspension System - General Information - Suspension 90 Front Live beam axle, linear rate coil springs, coaxial telescopic nitrogen-charged hydraulic shock absorbers. Lateral axle location by fabricated steel Panhard rod and longitudinal axle location by forged steel radius arms. Stabilizer bar if alloy wheels fitted. Rear Live beam axle, linear rate coil springs (dual rate for heavy duty derivative), telescopic nitrogen-charged hydraulic shock absorbers. Lateral axle location by forged steel 'A' frame arms and longitudinal axle location by fabricated steel trailing links. Stabilizer bar if alloy wheels fitted. 110 Front Live beam axle, dual rate coil springs, coaxial telescopic nitrogen-charged hydraulic shock absorbers. Lateral axle location by fabricated steel Panhard rod and longitudinal axle location by forged steel radius arms. Stabilizer bar if station wagon or crew cab derivative. Rear Live beam axle, triple rate coil springs, telescopic nitrogen-charged hydraulic shock absorbers. Lateral axle location by forged steel 'A' frame arms and longitudinal axle location by fabricated steel trailing links. Stabilizer bar if station wagon or crew cab derivative. 110 heavy duty and 130 Front Live beam axle, linear rate coil springs, coaxial telescopic nitrogen-charged hydraulic shock absorbers. Lateral axle location by fabricated steel Panhard rod and longitudinal axle location by forged steel radius arms. Stabilizer bar. Rear Live beam axle, triple rate coil springs, coaxial linear rate helper springs, telescopic nitrogen-charged hydraulic shock absorbers. Lateral axle location by forged steel 'A' frame arms and longitudinal axle location by fabricated steel trailing links. Stabilizer bar. Road spring data Road spring Part number Colour code 90 2 seat utility (2400 Kg) Front - Driver's side REB500200 Red/green/white Front - Passenger side REB500220 Red/green/orange Rear - Driver's side NRC 9448 Blue/red Rear - Passenger side NRC 9449 Yellow/white 90 2 seat utility (2550 Kg) Front - Driver's side REB500200 Red/green/white Front - Passenger side REB500220 Red/green/orange Rear - Driver's side RKB101230 Green/yellow/red Rear - Passenger side RKB101240 Green/yellow/white 90 4 seat station wagon (2400 Kg) Front - Driver's side REB500200 Red/green/white Front - Passenger side REB500220 Red/green/orange Rear - Driver's side RKB500290 Red/green/green Rear - Passenger side RKB500280 Red/green/red 90 4 seat station wagon (2550 Kg) Front - Driver's side REB500200 Red/green/white Front - Passenger side REB500220 Red/green/orange Rear - Driver's side RKB500270 White/green/pink Rear - Passenger side RKB500310 White/green/purple LHD 110 2 seat utility, 5 seat station wagon and 5 seat crew cab (3050 Kg) Front - Driver's side NRC 8044 White/white Front - Passenger side NRC 8045 Yellow/yellow Rear - Both sides RKB101111 Purple/brown RHD 110 2 seat utility, 5 seat station wagon and 5 seat crew cab (3050 Kg) Front - Both sides NRC 8045 Yellow/yellow Rear - Both sides RKB101111 Purple/brown LHD 110 7 seat station wagon (3050 Kg) Front - Driver's side NRC 8044 White/white Front - Passenger side NRC 8045 Yellow/yellow Rear - Both sides RKB500300 White/green/green RHD 110 7 seat station wagon (3050 Kg) Front - Both sides NRC 8045 Yellow/yellow Rear - Both sides RKB500300 White/green/green 110 heavy duty and all 130 (3500Kg) Front - Driver's side NRC 9448 Blue/red Front - Passenger side NRC 9449 Yellow/white Rear - Both sides 78 of 1212 RKB101111 Purple/brown |
12th Oct 2010 7:46pm |
Augusto Member Since: 01 Feb 2011 Location: Munich Posts: 35 |
How about sway bar quick disconnectors?
4th Feb 2011 9:06pm |
4th Feb 2011 9:07pm |
Martin90 Member Since: 12 Feb 2010 Location: Abu Dhabi Posts: 19 |
Allan, What suspension set up are you running as I have been thinking of removing ARB's on my 90 but do not want to reduce the onroad handling. Cheers, Martin Martin 1989 90 - Truck cab, Mazda 35 SLTi engine 2009 90 - Station Wagon |
5th Feb 2011 1:22pm |
