Home > In Car Electronics > Review: Defender Audio Install
Page 2 of 3 <123>
Barney12
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
Right then let's move to the 6" speakers right at the back.
Alpine SPR-60's
http://www.caraudiocentre.co.uk/product_m-...-27161.htm
Again these were a carful choice. I wanted as big as I could get away with without making the install look like a bodge! After a bit more careful measuring I was certain that I could make it work.
Yes, if you follow me then you are going to hack your rear quarter panels but when you consider they are circa £45 to replace that's not really a big hardship even if you decided to return your Defender to standard.
The other key factor was reducing any rattle so the panels at the rear were carefully sound deadened and the actual plastic panels had some off cuts of Dynamat applied too. The results are very good with only the loudest of tracks causing any rattle (and I'm talking seriously loud!). In fact the speakers themselves will distort ahead of any panel rattle.
As the pictures below show you need to carrfully cut away the ribs in the panel. Not too hard to do with a dremel and finished with a needle file. Unfortunately these two pics only show the work in progress, I think I lost interest in taking pictures after this!! Rolling Eyes
It is though a tight fit and you need to measure at least twice!
The finished result is perfect and there is no sign of any cutting, bodge or DIY. I'll try and take a couple of pics and update this thread.
Post #478441 2nd Dec 2015 7:26pm
Barney12
Lordsmut wrote:
How do you find the field of vision on the camera with it being offset?
It's absolutely fine. It's angle of view is wide enough to capture the full rear. You do though see a small section of tyre but those 18" Sawtooths mounted on the carrier are a monster!
Post #478442 2nd Dec 2015 7:31pm
Barney12
Right then, the last peice of the jigsaw.......
In my tests I found that the sound was just not "filling" the cabin in the way that I wanted. Now, I've got to be honest that I received a HUGE amount of conflicting advice on this part. Many said "it won't make any difference" and "don't connect two sets of speakers in parellel you'll get poor results". I guess this point takes me back to my first first sentences, we all have differing ears! For me I am completely happy, it's a huge improvement. The amp also drives this configuration with ease and is designed for the load it's getting.
http://www.caraudiocentre.co.uk/product_m-...-27163.htm
So what I did was get a set of 5" Alpines from the same range SPR-50's (link above) as the 6" rears and then set about testing the best position for them. Eventually I settled for immediately behind the front seats. They are built into some custom pods, again made from MDF and this time covered in the same carpet as the floor.
The result looks pretty seamless.
Post #478447 2nd Dec 2015 7:42pm
Barney12
You might just have spotted the carpeting detail in the last picture. I was insistant on that panel right behind the seats being carpeted. Oh and neat edge detailing too Thumbs Up
Can you see it. No not really unless you're sat in the rear seats (erm, OK they've never actually been sat in whilst the car is moving Shocked ) But I know it's right Mr. Green
Post #478449 2nd Dec 2015 7:47pm
Lordsmut
England 2011 Defender 90 Puma 2.4 XS CSW Santorini Black
Snap! I started with the G series Alpine and now have the R's like yourself
Post #478452 2nd Dec 2015 7:52pm
Barney12
Same position too! Thumbs Up
I found the R series are a significant upgrade on the G series. Definitely worth the extra money.
Post #478456 2nd Dec 2015 8:02pm
Lordsmut
Agreed Cool
Post #478471 2nd Dec 2015 8:38pm
Pickles
I'm following,......and if you lived near me, I'd offer you a job.
Impressed?.....VERY. Pickles.
Post #478514 2nd Dec 2015 9:59pm
DG123
Cheers Barney - thanks for taking the time to post this. Thumbs Up
The removable sub is a great idea - I've been angsting over this for ages as all my ideas got in the way of something at some point. Why didn't I think if moving it when needed Rolling Eyes 2012 110 XS SW Orkney Grey
2003 D2 Td5 Black [SOLD]
Post #478533 2nd Dec 2015 10:33pm
Barney12
Can I have a Summer job? I.e. I'll come from Nov to Feb so I miss the British winter Thumbs Up
Post #478569 2nd Dec 2015 11:40pm
Barney12
No problem. It's a relatively easy build. Here's the links to the other bits I used:
Acoustic carpet: http://www.ebay.co.uk/itm/400526589051?_tr...EBIDX%3AIT
Binding posts: http://www.ebay.co.uk/itm/2-Way-Speaker-Bo...51c21ca049
Grill: http://www.caraudiodirect.co.uk/phonocar-3-020-8-subwoofer-grille
Post #478573 2nd Dec 2015 11:56pm
DG123
Cheers - great info Thumbs Up 2012 110 XS SW Orkney Grey
Post #479475 5th Dec 2015 9:15pm
LoveTheMud
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Santorini Black
This looks the bees knees! Very impressed! Bow down
It's good to hear about the trial and error methods of the speakers position behind the seat - I think this is the kick of confidence from all the pictures and explanations that I needed - Thanks!
Out of interest, and because this bit wasn't clear to a novice such as myself (or i missed it) - do the speakers not move around when driving, or are they fixed in place some how?
I have an A-level in wood work (although never used), I think it's time I try to remember how to use a saw Laughing
Post #526156 23rd Apr 2016 11:04am
Barney12
Thank you Very Happy
No fixings, just a really good fit between the window/side panel and the carpeted floor, to do this you need to match the curve and angle of the panel which is a bit of a fiddle. I just made a cardboard template first. The top and the bottom edge of the enclosure has fabric tape attached which along with the tight fit creates enough friction.
They've never moved an inch.
Post #526340 24th Apr 2016 7:15am
jieming
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Zermatt Silver
Very jealous about all the kit you've been able to fit. At the completely opposite end of the scale is it possible to plug a Kenwood KSC-SW11 into the back of the standard land rover head. I have the original radio CD player fitted in my 2011 csw. Thought I'd ask for some advice before buying the sub only to find it won't connect.
Post #531767 15th May 2016 5:23pm
Page 2 of 3 <123>
