Home > Td5 > Front door seals (lower)
Page 1 of 4 1234>
excossack
Today I finally got around to replacing the lower door seal on the drivers and passenger doors.
On opening the door, the door now feels more springy than before, so hoping its a good seal.
But.....there is still a gap which I can see daylight through (circled)
Which seal am I missing to stop
A) Daylight
B) Draught
The daylight is the corner of the door where it meets the sill/B bottom of the B pillar
The seal I fitted was http://www.ebay.co.uk/itm/Land-Rover-Defen...SwrklVbvs~
(Gen LR part) 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #476778 27th Nov 2015 6:48pm
dorsetsmith
your missing these
Post #476781 27th Nov 2015 7:06pm
excossack
Excellent, and those sit in each corner, two per door? or one per door? 1999 Defender TD5 110
Regards
John M0VAZ
Post #476810 27th Nov 2015 7:40pm
dorsetsmith
two per door Thumbs Up
Post #476819 27th Nov 2015 8:06pm
excossack
One each corner, B pillar and A pillar? Stuck to the door or to the body work ? 1999 Defender TD5 110
Regards
John M0VAZ
Post #476848 27th Nov 2015 9:28pm
dorsetsmith
One each corner, B pillar and A pillar yes
Stuck to the door
Post #476850 27th Nov 2015 9:31pm
excossack
Excellent - cheers. 1999 Defender TD5 110
Regards
John M0VAZ
Post #476855 27th Nov 2015 9:37pm
excossack
As a side note just ordered new rear door seals but have gone for the later Puma style ones as they look better than the L shaped rubber strips. I might consider doing the same to the front doors as well.
Just wondering, do the later Puma seals negate the need for the foam pads? 1999 Defender TD5 110
Regards
John M0VAZ
Post #477655 30th Nov 2015 2:04pm
driver9
Simple answer yes on a Puma not sure about a TD5.
Post #477661 30th Nov 2015 2:22pm
dorsetsmith
no because they have side rubber back and front but to fit them on older door isn't an easy job !
see below
Post #477662 30th Nov 2015 2:23pm
excossack
Cheers Driver 9
What makes it a difficult job to fit these seals to a Td5? 1999 Defender TD5 110
Regards
John M0VAZ
Post #477669 30th Nov 2015 2:35pm
gilarion
Some good info on fitting the later seals to TD5's here
http://www.defender2.net/forum/topic6370.h...door+seals For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #477705 30th Nov 2015 4:17pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Post #477725 30th Nov 2015 5:04pm
excossack
Cheers I will have a look. 1999 Defender TD5 110
Regards
John M0VAZ
Post #477806 30th Nov 2015 8:33pm
miker
Might have to get a set of those! Need to replace all the metal at the bottom of the door first though...
Post #478518 2nd Dec 2015 9:07pm
Page 1 of 4 1234>
