Home > In Car Electronics > Switch illumination |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5054 |
If you are unsure you could run a light feed a put a relay in it.
I dont know about carling swtiches but the light is usually low draw anyway. I wouldnt have an issue with 3 or 4 off 1 feed Mike |
16th Nov 2015 6:47pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4794 |
Should be absolutely fine to connect 6, they are illuminated by leds so 6 from the same connection will be ok 2002 90 Td5 Station Wagon
16th Nov 2015 8:00pm |
Yannis Member Since: 02 Feb 2015 Location: Oxfordshire / Milan Posts: 408 |
Are all the current illuminations run off 1 circuit?
Does anyone have a wiring diagram? |
16th Nov 2015 8:27pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 503 |
PM me your email address, and I'll send you the 2015MY dash illumination wiring diagram
. Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
16th Nov 2015 8:34pm |
dave18 Member Since: 11 Jul 2015 Location: Gorleston, Great Yarmouth Posts: 497 |
The current draw per switch is stupidly low ive got 10 switches with their ilumination being fed of the dash dial bulb feed with no issues.
17th Nov 2015 9:32am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20583 |
Dash bulbs are 1.2w IIRC.
So current draw is approx 0.8A - 1.1A Max |
17th Nov 2015 11:20am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6634 |
Within sensible limits (i.e. not 1000!) you can run all your switch illumination from the Red/Orange factory wiring.
What illumination method are the Carling switches, LED or bulb? 1988 90 Td5 NAS soft top 2015 D90 XS SW |
17th Nov 2015 11:30am |
0.1 Amps @ 12V 1988 90 Td5 NAS soft top 2015 D90 XS SW |
17th Nov 2015 11:32am |
