Home > In Car Electronics > Switch illumination
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
Switch illumination
Hi,
I have had a search but nothing has come up answering my question specifically.
I am about to install 6 carling switches into the shiny dash of my puma. Most of the posts I have looked at have said you can run an illumination feed from an existing switch. This seems ok for 1 switch, but can I link all 6 switches to the same feed of an existing switch or will this draw to much?
Thanks
Post #473166 16th Nov 2015 6:33pm
mse
If you are unsure you could run a light feed a put a relay in it.
I dont know about carling swtiches but the light is usually low draw anyway. I wouldnt have an issue with 3 or 4 off 1 feed Mike
Post #473171 16th Nov 2015 6:47pm
grafty99
Should be absolutely fine to connect 6, they are illuminated by leds so 6 from the same connection will be ok Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #473198 16th Nov 2015 8:00pm
Yannis
Are all the current illuminations run off 1 circuit?
Does anyone have a wiring diagram?
Post #473219 16th Nov 2015 8:27pm
PaulMc
PM me your email address, and I'll send you the 2015MY dash illumination wiring diagram Thumbs Up
. Paul.
Post #473228 16th Nov 2015 8:34pm
dave18
United Kingdom 1984 Defender 110 300 Tdi CSW Portofino Red
The current draw per switch is stupidly low ive got 10 switches with their ilumination being fed of the dash dial bulb feed with no issues.
Post #473401 17th Nov 2015 9:32am
Dash bulbs are 1.2w IIRC.
So current draw is approx 0.8A - 1.1A Max
Post #473437 17th Nov 2015 11:20am
Martin
Site Admin
Within sensible limits (i.e. not 1000!) you can run all your switch illumination from the Red/Orange factory wiring.
What illumination method are the Carling switches, LED or bulb?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #473443 17th Nov 2015 11:30am
Martin
Site Admin
0.1 Amps @ 12V Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #473445 17th Nov 2015 11:32am
