![]() | Home > My Defender > It's not a Jeep! (110 TD5 CSW) |
![]() Love that 110. On the list of Defenders I wouldn't mind owning myself ![]() |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1776 ![]() ![]() ![]() |
Thank you for the kind words! The old beast seems to be garnering quite a bit of fondness on here!
The last couple of days didn't quite go to plan. Pulled up at home to the strong smell of diesel, looked underneath and I kid you not there was a stream running off the diff case. The source of the leak was the hose that runs to the front of the block from the FPR. It was more of a sprinkler than a hose! Sourced a replacement, huffed, puffed and cursed in the dark to get it swapped over, and hopefully it should improve the running, as I suspect that was there all along, just not quite as badly. Either way, a picture of the new face, with wipac crystals, clear LED sidelights and Wipac spots on the bumper. ![]() Last edited by miker on 14th Aug 2017 6:04pm. Edited 1 time in total |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10965 ![]() ![]() |
Looking good there Miker with the new front additions, glad you got your problem solved
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 ![]() ![]() |
That not good news
![]() Theres always a silver lining though once you have sorted the engine you'll find something else that needs doing. ![]() Chin up its a keeper ![]() |
Hopefully whether I end up rebuilding or replacing, I should be able to find and cure the latent running issues!!
Replacement engine sourced, and beasty recovered home from a mates house to get cracking on the rebuild.
![]() Click image to enlarge20160116_140059 by Mike Redgrave, on Flickr Here behind a friends defender, on another friends trailer! Defender owning friends are the best kind! I now have to endure much ribbing about this being the second occasion that my TD5 has been rescued by an old 300tdi! Last edited by miker on 14th Aug 2017 6:06pm. Edited 1 time in total |
Pilgrimmick Member Since: 16 Nov 2015 Location: Highlands Posts: 582 ![]() ![]() |
Maybe you should swap the replacement engine for a tdi! 80" 1948
Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
The idea has been discussed! But I'm daft and stubborn and do quite like the td5 when it runs well!
Brief update of the last ten weeks:
Sourced (in the end) A replacement 15P TD5 engine, 5 injectors, a new flashable ECU, Fluids, gaskets and other stuff, Replacement lower rad hose (don't ask, on refitting it got wedged against the lower pulley. Didn't notice, rubbed through, water everywhere), Replacement thermostat (hot heater!) and many hours of labour (thanks go to my dad, luke off here and several friends) Then this happened: ![]() Click image to enlarge20160124_144419 by Mike Redgrave, on Flickr Put it all back in to find we couldn't select any gears. ![]() Click image to enlarge20160130_164805 by Mike Redgrave, on Flickr The next day dropped the box to flip the clutch around (doh!) Then this happened: (Hurrah!!) http://vid391.photobucket.com/albums/oo359...abhwrr.mp4 Then spent some time tarting bits up and getting everything we took off back on. Went to dartmoor with my scout group over the easter weekend, so between shakedown runs at that I've been back on the road for ~1500 miles. ![]() Click image to enlarge20160325_104055 by Mike Redgrave, on Flickr Next jobs, driveline clunk, footwell leaks, speakers in the rear and sorting the doors! Last edited by miker on 14th Aug 2017 6:07pm. Edited 2 times in total |
Good update, would of loved to have seen the pics to
![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Hopefully fixed!
Many thanks miker
Base camp was cockingford (Referred to by my old scout leader as the coldest camp on earth).
Groups were out on routes that cover a fair area, but covered Fensworthy, burrator, hameldown, princetown, two bridges etc. |
Your first Land Rover but you're already learning a lot about its innards :/
Still, so long as it doesn't let you down in a dangerous way with a load of Scouts on board it's all a learning experience. |
