Home > Maintenance & Modifications > Dash. Warning brake light
Rarely I notice on steep descents especially changing down on low gears I notice the dash brake light coming on intermittently.
It doesn't ever stay on just lights up momentarily then goes off soon enough.
It never does this unless in this situation so I'm ruling out handbrake and thinking maybe the brake fluid float is moving around?
If it wasn't for this I would be thinking handbrake wire but it works perfectly as it should and doesn't cause any issues at all unless on a decent that is steep usually downhill and in lower gears.
Any ideas?
Might be worth checking the handbrake switch and wires though I suppose.
Post #472800 15th Nov 2015 7:39pm
midlife
Ireland 2007 Defender 90 Puma 2.4 SW Rimini Red
Mine did this. It was fluid level. I gave it a slight top up and not done it sincr
Post #472801 15th Nov 2015 7:41pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
My light has started coming on lately too, it appears to be the handbrake which isn't returning fully to the off position. I also need to check/adjust the switch.
cheers
simon
Post #472803 15th Nov 2015 7:43pm
PK1
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Also, the push on blade connector on the handbrake can become loose making the light intermittent.
Quick check is to squeeze the gaiter when the handbrake is off and if the light comes on it is most probably the connector. Wink Defender 110 TDCi XS SW
Range Rover Sport HSE
Post #472813 15th Nov 2015 8:10pm
GSLRO
United Kingdom 2002 Defender 110 Td5 CSW Chawton White
Ditto Thumbs Up Adventure isn't paved!
Post #472834 15th Nov 2015 9:03pm
Mo Murphy
Yup, as the other chaps say it's your fluid level. As you go down the incline the fluid moves to the front of the reservoir and as a result the level under the float drops allowing the low level switch to close and bring on the light on your dash.
HTH
50 Shades of Pennine Grey
Post #472847 15th Nov 2015 9:29pm
Excellent, so I'll check.
I'm pretty sure the fluid level is where it should be though but I'll have a look.
May as well check the handbrake too.
Will have a poke around tomorrow hopefully.
Thumbs Up
Thank-you for suggestions too. Thumbs Up
Post #472855 15th Nov 2015 9:36pm
jimbob7
As said top up,it's a very fine line between being "empty" and "full". Pov.spec,ftw. 2006, 110,TD5.
Post #472966 16th Nov 2015 8:11am
Dave Bellis
United Kingdom 2014 Defender 90 Puma 2.2 HT Keswick Green
Had exactly the same and as previously posted a slight top top up of the brake fluid cured the problem....
Dave
Post #473157 16th Nov 2015 6:13pm
I had a look just at the fluid level today.
You chap are right, it has dropped slightly but still much much more nearer the max level but that us probably enough.
Need to look up the specs to get some more..
Post #473162 16th Nov 2015 6:24pm
jimbob7
dot 4,might as well blow fresh fluid thru the lot,must be getting cloudy by now?? Pov.spec,ftw. 2006, 110,TD5.
Post #473185 16th Nov 2015 7:26pm
I will get the brake fluid changed completely and bled shortly.
In the mean time I'll top up slightly.
Does anyone know the Specs LR use? Other than DOT4 of course.
Looking on opie's site earlier there is Castrol react, a regular Castrol a slightly cheaper one and a Shell version.
I think it's most likely Castrol used before.
I've been trying to look to find out what was used when I was changed but I can't seem to find the info I need.
Opie's site layout for vehicle specs has changed slightly too, so it's not as easy to work out.
Post #476074 25th Nov 2015 1:19pm
jimbob7
I use any branded stuff for quality assurance,Castrol,Mobil and Pagids from Eurocarparts is cheap in bulk.Mobil available from Halfords but not cheap.
Other than that dot 4 is dot 4.Not like engine oil where there is a,b,c,d spec...ffs Confused Demon tweeks on eblag is about cheapest for Castrol. Pov.spec,ftw. 2006, 110,TD5.
Post #476077 25th Nov 2015 1:26pm
K9F
For perfectionists, purists or those like myself with mild OCD. Workshop Manual states......
Recommended hydraulic fluid SHELL DONAX YB DOT4 ESL FLUID
Thumbs Up Cool If you go through life with your head in the sand....all people will see is an ar5e!!
Post #476079 25th Nov 2015 1:39pm
There are specs applicable as they are mentioned on the page.
K9 - Spotted that one, probably go with that then. Thank-you. Thumbs Up
Post #476080 25th Nov 2015 1:45pm
