Home > Maintenance & Modifications > Dash. Warning brake light
Page 2 of 2 <12
ericvv
Steve, how frequently do you change your brake fluid? Irrespective of mileage done, should be replaced every two years due to its tendency to absorb moisture.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #476088 25th Nov 2015 2:44pm
Yeah, read in the manual.
I get the dealer to do it as it's brake related.
And yes, they don't include it in a regular service it has to be mentioned at the same time.
I've got a full service. (Larger one) coming up this coming year so I'll have the brake fluid changed too.
I won't like the price though. Big Cry Shocked
For the time being I'll go with what K9 suggested as a top up then get it changed when serviced.
Opie are doing a good discount for us right now too. Thumbs Up
Post #476109 25th Nov 2015 4:22pm
jackp
United Kingdom 2009 Defender 90 Puma 2.4 PU Stornoway Grey
Did this solve the problem?
Post #516371 21st Mar 2016 10:46am
Hi,
Yes, topping up did indeed cure the problem permanently.
It didn't even look like it needed topping up but a very small amount and it was gone.
It was definitely the cause. Thumbs Up
Post #516391 21st Mar 2016 12:23pm
My Defender is the same, in order to stop the light flickering when braking facing downhill I have to keep the fluid level (on the flat) a little higher than the MAX mark on the reservoir, just about up to the bottom on the filler neck in fact.
If I do this, the light doesn't flicker.
Seems to be a landrover thing!
Post #516419 21st Mar 2016 2:01pm
The float in there must be slightly higher than it actually should be.
I suppose better that than too low though.
Post #516435 21st Mar 2016 3:07pm
jackp
Worked for me, however I have noticed that my pads are getting low and I think this is why my light is flickering as the fluid is much lower due to the increased displacement of the brake system - topped up for now but will change and flush when the disks and pads are done.
Thanks for your help.
Post #524223 15th Apr 2016 1:16pm
Page 2 of 2 <12
