Home > Maintenance & Modifications > Dash. Warning brake light |
midlife Member Since: 15 Apr 2015 Location: Cork Posts: 122 |
Mine did this. It was fluid level. I gave it a slight top up and not done it sincr
15th Nov 2015 7:41pm |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
My light has started coming on lately too, it appears to be the handbrake which isn't returning fully to the off position. I also need to check/adjust the switch.
cheers simon |
15th Nov 2015 7:43pm |
PK1 Member Since: 19 Oct 2012 Location: Gloucestershire Posts: 96 |
Also, the push on blade connector on the handbrake can become loose making the light intermittent.
Quick check is to squeeze the gaiter when the handbrake is off and if the light comes on it is most probably the connector. Defender 110 TDCi XS SW Range Rover Sport HSE |
15th Nov 2015 8:10pm |
GSLRO Member Since: 13 May 2012 Location: Tyne and Wear Posts: 499 |
^ ^ ^ ^ ^ ^ ^ ^ ^ Ditto Adventure isn't paved! |
15th Nov 2015 9:03pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2214 |
Yup, as the other chaps say it's your fluid level. As you go down the incline the fluid moves to the front of the reservoir and as a result the level under the float drops allowing the low level switch to close and bring on the light on your dash.
HTH Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
15th Nov 2015 9:29pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20280 |
Excellent, so I'll check.
I'm pretty sure the fluid level is where it should be though but I'll have a look. May as well check the handbrake too. Will have a poke around tomorrow hopefully. Thank-you for suggestions too. |
15th Nov 2015 9:36pm |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
As said top up,it's a very fine line between being "empty" and "full". Pov.spec,ftw. 2006, 110,TD5.
16th Nov 2015 8:11am |
Dave Bellis Member Since: 21 May 2014 Location: Shrewsbury Posts: 133 |
Had exactly the same and as previously posted a slight top top up of the brake fluid cured the problem....
Dave |
16th Nov 2015 6:13pm |
I had a look just at the fluid level today.
You chap are right, it has dropped slightly but still much much more nearer the max level but that us probably enough. Need to look up the specs to get some more.. |
16th Nov 2015 6:24pm |
dot 4,might as well blow fresh fluid thru the lot,must be getting cloudy by now?? Pov.spec,ftw. 2006, 110,TD5.
16th Nov 2015 7:26pm |
I will get the brake fluid changed completely and bled shortly.
In the mean time I'll top up slightly. Does anyone know the Specs LR use? Other than DOT4 of course. Looking on opie's site earlier there is Castrol react, a regular Castrol a slightly cheaper one and a Shell version. I think it's most likely Castrol used before. I've been trying to look to find out what was used when I was changed but I can't seem to find the info I need. Opie's site layout for vehicle specs has changed slightly too, so it's not as easy to work out. |
25th Nov 2015 1:19pm |
I use any branded stuff for quality assurance,Castrol,Mobil and Pagids from Eurocarparts is cheap in bulk.Mobil available from Halfords but not cheap.
Other than that dot 4 is dot 4.Not like engine oil where there is a,b,c,d spec...ffs Demon tweeks on eblag is about cheapest for Castrol. Pov.spec,ftw. 2006, 110,TD5. |
25th Nov 2015 1:26pm |
For perfectionists, purists or those like myself with mild OCD. Workshop Manual states......
Recommended hydraulic fluid SHELL DONAX YB DOT4 ESL FLUID If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 25th Nov 2015 1:58pm. Edited 2 times in total |
25th Nov 2015 1:39pm |
There are specs applicable as they are mentioned on the page.
K9 - Spotted that one, probably go with that then. Thank-you. |
25th Nov 2015 1:45pm |
