Home > Maintenance & Modifications > Dash. Warning brake light |
Steve, how frequently do you change your brake fluid? Irrespective of mileage done, should be replaced every two years due to its tendency to absorb moisture.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
25th Nov 2015 2:44pm |
jackp Member Since: 30 Apr 2015 Location: West Sussex Posts: 31 |
Did this solve the problem?
21st Mar 2016 10:46am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20281 |
Hi,
Yes, topping up did indeed cure the problem permanently. It didn't even look like it needed topping up but a very small amount and it was gone. It was definitely the cause. |
21st Mar 2016 12:23pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17319 |
My Defender is the same, in order to stop the light flickering when braking facing downhill I have to keep the fluid level (on the flat) a little higher than the MAX mark on the reservoir, just about up to the bottom on the filler neck in fact.
If I do this, the light doesn't flicker. Seems to be a landrover thing! |
21st Mar 2016 2:01pm |
The float in there must be slightly higher than it actually should be.
I suppose better that than too low though. |
21st Mar 2016 3:07pm |
Worked for me, however I have noticed that my pads are getting low and I think this is why my light is flickering as the fluid is much lower due to the increased displacement of the brake system - topped up for now but will change and flush when the disks and pads are done.
Thanks for your help. |
15th Apr 2016 1:16pm |
