Home > Puma (Tdci) > All driving lights died!!!!
I-Landy
United Kingdom 2007 Defender 130 Puma 2.4 HCPU Baltic Blue
Evening,
Just driving along moments ago, headlights on when all of a sudden the lights died (Headlights, Rear lights, dash lights-Brake, indicator and reverse lights still working)...currently stranded but I'll probably ditch it and retrieve it tomorrow in daylight. Anyone recommend a fix? I have looked through the fuses but guessing something more as all lights died. Cheers
Post #467901 30th Oct 2015 6:46pm
I-Landy
Also it's a 07 puma (tdci) 130 HCPU should that make a difference...
Post #467906 30th Oct 2015 6:55pm
K9F
http://www.defender2.net/forum/topic20817....ght+switch
http://www.defender2.net/forum/topic19350....elay[/url] If you go through life with your head in the sand....all people will see is an ar5e!!
Post #467913 30th Oct 2015 7:02pm
I-Landy
Thanks K9F, very helpful
Post #467915 30th Oct 2015 7:10pm
K9F
Welcome. If you're technical acumen isn't up to it (no offence meant) I may be able to assist as you appear to be local. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #467918 30th Oct 2015 7:15pm
Main light switch on left of column has melted. Very common occurence! Big Cry
If you move the switch to the side and tail position you may get side and tail lights back, in which case as an emergency measure you can short out the two wires connected to the dim-dip resistor (just under the RH wing top near the aerial) which will give full dip beam whenever the sidelights are on.
Permanent solution is to rewire the headlights through relays.
Post #467919 30th Oct 2015 7:18pm
I-Landy
Thanks K9F, I will give it a look myself in daylight conditions but failing that I'll be in touch, appreciate that. Thumbs Up
Cheers Blackwolf, I try that. Thumbs Up
Post #467921 30th Oct 2015 7:34pm
I-Landy
This won't come as a surprise I doubt but the issue is in fact the switch, the contacts have melted into the plastic (see picture). New switch to be ordered and jobs a good un' . Thanks for your help, why does this happen?
Post #468100 31st Oct 2015 3:47pm
I-Landy
Post #468101 31st Oct 2015 3:48pm
Devon-Rover
United Kingdom 2014 Defender 110 Puma 2.2 USW Aintree Green
It happens as land rover in their infinite wisdom do a very simple lighting circuit which means the full voltage (and Wattage) is run through the switch.
It goes Battery ---- Fuse box --- Switch main ----- Switch hi - lo ----- Lights..
Instead of running a low current switching circuit to some relays and then running the main voltage to the lights through the relay.
In short (Pun of the day) the full current of the lights through the switch contacts (A resistance Point) creates heat and this melts them.
Post #468106 31st Oct 2015 4:01pm
I-Landy
I see. Thanks for the explanation. Hence fitting a relay to fix the problem. Idea
Post #468108 31st Oct 2015 4:15pm
