Home > Maintenance & Modifications > 200tdi Head Removal, Inspection, Refitting
Page 2 of 4 <1234>
dorsetsmith
Post #459351 30th Sep 2015 7:58pm
shaggydog
Have you used them before?
Didn't know they existed! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #459355 30th Sep 2015 8:05pm
dorsetsmith
NO only sedation Exclamation
Post #459357 30th Sep 2015 8:10pm
shaggydog
Laughing
Thanks Dorset Wink Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #459358 30th Sep 2015 8:13pm
dorsetsmith
Post #459361 30th Sep 2015 8:19pm
g-mack
shaggy, its a keeper, i would bite bullet and get a one from turners!! Thumbs Up My 109 thread
my youtube channel
Post #459372 30th Sep 2015 8:45pm
dorsetsmith
Good thing in buying from Turner engineering is you will have guarantee on the head Exclamation
Post #459377 30th Sep 2015 8:55pm
shaggydog
I have gone for the Turner head, everything else just looked too much like a gamble and an expensive one at that (not that the Turner engineering option was the cheapest by any stretch Rolling Eyes)
I'm hoping to have a good run at it tomorrow so hopefully photos to update then.
In the mean time, if you have a 200Tdi head - For god sake look after it! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #459790 2nd Oct 2015 11:22am
dorsetsmith
As most Turner replacement head TD5 and 2.5 are made spain i wonder why they aren't making Tdi 200 heads too Question
Post #459827 2nd Oct 2015 1:59pm
shaggydog
I don't know to be honest, but I imagine its down to cost.
I think it might be because the head design is very complex and the patterns are well gone.
I think the Td5 heads from Spain are the original manufacturer anyway- they just never stopped making them.
300Tdi was mass produced until very recently and you can still get variants of it but its so different from a 200Tdi head you cant use it or modify it.
I did wander about looking into getting a load cast up but the amount of hours to design a new core box and pattern are mind boggling and the numbers I imagine quite scary.
Shame really as otherwise its a bulletproof engine! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #459828 2nd Oct 2015 2:10pm
shaggydog
Right, bits mostly arrived.
Before I fit the head, is there anything I should do?
I am thinking of giving the engine a good degrease, fit the head. New coolant, same oil but run a oil flush and then change oil and filter.
Anything else I should change?
How can you test Glow Plugs? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #459945 2nd Oct 2015 9:30pm
g-mack
concentrate very very hard when re torquing head bolts. i was marking mine as i went through sequence and got to 14 ish lost concentration and could remember if i had tightened and not marked or not tightened! lol its a pressure situation haha.
i used a marker and numbered top of bolts too so i didn't need to keep checking manual. be careful with that too as i nearly tightened 9 before 6 as they look same from different angles!! lol My 109 thread
my youtube channel
Post #459985 2nd Oct 2015 11:20pm
g-mack
also chech re check and check again that the gasket is spot on position and head seated nicely in dowels before tightening
my youtube channel
Post #459987 2nd Oct 2015 11:25pm
shaggydog
Well noted G-Mack Bow down
Did you change the oil when you did yours? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #459989 2nd Oct 2015 11:30pm
g-mack
yea i changed oil and filter and coolant. don't forget to pour a little oil over the rockers before you put cover on, i gave them all a good dowsing to get a bit of lube on them and into the rods and valve stems My 109 thread
my youtube channel
Post #459999 3rd Oct 2015 12:24am
Page 2 of 4 <1234>
