Home > My Defender > Corris 110....
Page 42 of 48 <123 ... 414243 ... 464748>
L110CDL
Cant beat a " sleeper " Andy Whistle Clayton.
Keeper.
Post #561390 4th Sep 2016 8:55pm
mcma1
Post #562156 7th Sep 2016 2:52pm
Bomber82
Italy 2009 Defender 110 Puma 2.4 SW Zermatt Silver
Great truck! Thumbs Up Matteo
Defender 110 Td4 SE MY 09
Post #573541 26th Oct 2016 2:22pm
L90DNY
United Kingdom 2006 Defender 90 Td5 HT Corris Grey
Just read the whole thread, so epic! Really inspirational of what can be done. Keep up the good work, will be following the V8 thread now!
Post #573824 27th Oct 2016 7:49pm
ericvv
mcma1 wrote:
I did add the lights into the front footwells, into the underside of the dash as this was a good place to get a good secure fit.. Just a 35mm hole needed then dremel'd out for a good fit. Wired into the interior lights so they come on with the remote and then also wired to come on with the side/headlights etc. Hard to get pictures but even off centre they light up the footwell really well, nice and subtle. I do plan to change all the interior bulbs to LED which should help even more.
Bit of a thread revival... I have two of these waiting to be installed for some time now and want to finally go ahead with that.
Andy, was there an easy way to wire them into the interior lights circuit? Is taking the center dash panel with the radio out sufficient to do this, or is it more difficult, maybe a complete dash out job? (Hope not). What is the best and easiest way? For me, I just would like them to come on and go off with the interior lights, nothing else.
Thanks, Eric
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #580019 24th Nov 2016 6:35am
mcma1
Hi Eric,
I have them on with the illumination feed so on at night, however my door courtesy lights have there own circuit. I have just taken a feed from the interior light wire in the A pillar. This is a switched ground which just triggers the relay. Because of the dimming feature the first relay buzzed shortly, I tried another brand and it is all good. Shout if you need more detail. Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #580063 24th Nov 2016 10:20am
ericvv
Andy, when you say "taking a feed from the interior light wire in the A pillar".
Do you mean from the backside of the little switch button low in the A pillar which comes out of its rest position when you open one of the front doors?
Thanks for confirming this or if that is not it please point me in the right direction.
Best, Eric You never actually own a Defender. You merely look after it for the next generation.
Post #582881 5th Dec 2016 5:25pm
mcma1
Hi Eric,
This is the thread I started for my door courtesy lights, follow it and you will be sorted!
http://www.defender2.net/forum/topic43766....rior+light Andy
2014 Corris 110 SW
LS3 V8 build...
Post #582886 5th Dec 2016 5:56pm
mcma1
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Andy
2014 Corris 110 SW
LS3 V8 build...
Post #582888 5th Dec 2016 5:59pm
ericvv
PaulMc wrote:
mcma1 wrote:
Ah just realised my mistake!! Yes I want these to come on if any door is opened, as there are 5 door switches in the 110 and only 2 interior lights, does that not suggest the 5 switched grounds come together somewhere?? It would save me having to tap into 4 switches if I could tap in somewhere else common to all the doors?? What do you think?
The driver's door switch is on its own wire (Grey/White trace), which goes back to C0061-5 in the 10AS unit's Grey connector.
The wires (Purple/Blue trace) from all of the other door's switches, are spliced together and go back to C0061-16 in the 10AS unit's Grey connector.
To add extra interior lamps, you don't need to wire anything to the door switches.
The door switches signal the 10AS unit to provide an earth path to the interior lamps on the Purple/White trace wire at each of the interior lamps.
So, to wire additional interior lamps to fade on and off with the factory fitted interior lamps, you should wire them to the interior lamps permanent live (Purple/Brown trace), and the interior lamps 10AS controlled earth on the Purple/White trace wire.
Still a bit confused after reading the other thread and then look at Andy's schematics in above post.
Andy's drawing in above post seems to show a relay.
But PaulMc's comments which I quoted here above are saying that we do not need a relay for additional interior lights which come on and fade out together with the other existing interior lights.
Is it possible for someone to show on a drawing how this then would look like?
Thanks, Eric You never actually own a Defender. You merely look after it for the next generation.
Post #583025 6th Dec 2016 10:52am
ericvv
Post #583400 8th Dec 2016 6:28am
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
Re: Footwell lights
mcma1 wrote:
Making up a little loom now for the front footwell lights... They are from a FFRR but think they are the same as the lights in the svx cubby??
Hi Andy,
Do you know the part number of the connector for the footwell light ( XDC500070 )?
Thanks
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #590452 5th Jan 2017 7:26pm
Procta
What a build thread! you cannot beat lux! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #598204 1st Feb 2017 7:10am
Gutch1985
Mint and great read Very Happy
Post #598680 2nd Feb 2017 8:48pm
CR
Ireland 2011 Defender 110 Puma 2.4 CSW Santorini Black
did you get the interior finished, would love to see it?
CR
Post #602678 17th Feb 2017 8:11pm
