Home > Td5 > Discovery td5 transfer box gearbox into defender td5 advice
Page 2 of 3 <123>
tasr12
England 2002 Defender 110 Td5 CSW Zambezi Silver
Thanks - that would definitely put the light, wheel carrier and a few other bits on hold! 2002 110 CSW TD5, Zambezi Silver
1995 110 CSW 300TDi - SOLD
Post #455668 16th Sep 2015 8:57pm
tasr12
If I stick a Disco transfer box do I need to then re-map to make it worhtwhile? If I don't re-map the ECU will I be in no-mans land in terms of driveability? 2002 110 CSW TD5, Zambezi Silver
Post #455804 17th Sep 2015 1:38pm
foxing
Wales
tasr12 wrote:
Lambley wrote:
A transfer box straight from a Td5 disco, cost me £100 and I got £170 for mine!
At this price I would do it tomorrow! What am I likely to pay through an LR Specialist? On investigation my transfer box is leaking at the front (not the rear output seal as I thought/hoped). If the box is coming off to remedy I'm considering looking for a Disco transfer box to switch in for the much talked about advantages. However, this was always planned way down the line. What am I looking at in terms of supply and fit cost wise - even just a steer would be appreciated! If it's coming off anyway it would make sense to do it now.
I've barely managed anything I had planned as I'm still fault finding and remedying. The scenelight/rear work light keeps getting bounced down the list = frustrating.
T.
just had one fitted with a full rebuild,best thing I've done to the defender will sit at 70-75 at only 2500 revs.Had all the work done by https://www.facebook.com/FatCat4x4 [/url] give Shane a call for a quote had mine done for a very good price
atb paul
Post #455826 17th Sep 2015 2:40pm
tasr12
Thanks - will follow that up. 2002 110 CSW TD5, Zambezi Silver
Post #455866 17th Sep 2015 4:48pm
tasr12
Haven't been able to get hold of Shane. If I do change the T-box for a Disco one does it need a remap to make it worthwhile. Funds won't allow c.£300 for a remap so if I just change the box will I be left with a worse set up than I have on the standard T-box now.
I wasn't going to do the T-box now but as the seals on the current one need changing it seems like the best time to change it if it worth it without a remap?
Thoughts appreciated,
Tom. 2002 110 CSW TD5, Zambezi Silver
Post #458158 26th Sep 2015 9:58am
mk1collector
I've changed the t box and haven't had mine mapped (yet) it does change the way it drives (obviously) and I found I needed more revs out of junctions etc but at higher speeds and motorways it much quieter and smoother. So I guess it depends on what roads you drive weather it's worth changing. Ashcroft do a service where if you are getting the t box refurbed they can put the disco gears into your box so you don't have to change the font cone and drive shaft couplings over. Ray
My build thread
Post #458173 26th Sep 2015 11:00am
tasr12
Thanks the reply - I'm mainly A-roads to get to where I need to be and then over fields and tracks when out with the dog. A few more revs at the junctions I can live with if it's still sensible? Being able to sit at 60-70 with less revs is appealing though, presumably it helps on the fuel consumption? I suppose the re-map could come down the line, but I don't want to compromise what it does over the winter when it may be in soft fields etc. as I doubt I will be getting the ECU done before next summer.
Cheers. 2002 110 CSW TD5, Zambezi Silver
Post #458184 26th Sep 2015 12:13pm
mk1collector
It felt strange at first but you get used to the extra revs low down quickly and it's not excessive. Mines a road queen so I can't comment on any off road but I can't see it making much difference on grass etc and with you doing a roads it will probably be a good addition for you. Alternatively ashcrofts do a higher 5th gear for the gearbox if you want to keep the transfer box standard which will be better at motorway speeds and keep pulling away from junctions less revy. Ray
My build thread
Post #458189 26th Sep 2015 1:05pm
Martin
Site Admin
I haven't felt the need for a remap, mine's a 90 though but running tall tyres as well (265/75R16).
Martin  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #458194 26th Sep 2015 2:29pm
mk1collector
I'm the same Martin, it doesn't need a remap but I think it would make a good improvement when pulling out from junctions etc. Ray
My build thread
Post #458195 26th Sep 2015 2:35pm
tasr12
A lot to think about - the 5th gear ratio appeals, I may need to research that.
Has anyone got a non-remapped T-fer box change view on the off road capability? My thinking is that there is still always low ratio?
Post #458215 26th Sep 2015 4:40pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
I had mine remapped before I swapped the transfer box over so I never drove it with standard power on the higher ratio. I have used the low box though - at home we've got a very steep bit of land with an orchard at the top, I used the low ratio box to get up the steep hill (prob a 40 degree slope, backwards) and pulling out some small trees, I've also used it in the field for towing a grass topper, the low box is very useful now and then.
As for fuel consumption - the t/box helps, but the biggest gain was the remap, I got around 2/3mpg better after a remap (std t/box) and possibly 3/4 after swapping the t/box.
I don't really do any off roading, mainly just A to B around Devon. It's hilly and twisty in parts and some lanes/roads need to be taken slowly so there can be lots of gear changing when narrow roads limit visibility.
To be honest - if you have no intention of a remap I'd stick to standard gearing, if you are thinking of a remap soon after swapping the t/box then it makes the mod worthwhile.
Just my 2 penneth
Post #458301 27th Sep 2015 7:08am
Toby60
United Kingdom 2002 Defender 90 Td5 HT Coniston Green
I'm having the transfer box on my TD5 90 HT converted from the standard 1.4 to the Disco 1.2 at Ashcrofts within the next couple of weeks and I am not intending to have a remap. I sometimes tow a 1.5 tonne trailer and don't do any off-roading. Reading the comments from others on this forum I feel happy that I am making the right choice. I'll post a comment once it's done. ------------------------------------------------
2002 TD5 90 HT County
Post #458308 27th Sep 2015 7:43am
tasr12
For what it's worth - Discovery Transfer put in by AL Services yesterday. I picked it up at lunch today and drove the 15mins back to work and I have to say that initial impressions are very good. It might lack a little Hp at the top end but on the flat/marginal down hill it comforably pushed 80mph. More improtantly in the mid-range it was far nicer to drive.
Time will tell when I get it in to the fields but I barely noticed the increased rev requirement.
Thanks for the views to date. I'm sure a re-map would make it better again but currently funds won't allow.
Great service from AL Services. They also wired up a rear work light to come on when reverse is selected. My next question for the electrical experts is how easy will it be to run a switch forward to the dash with a permanent live so I have one there? Occasionally I park on a hill and need the work light so don't want to have to keep killing the engine and leaving it in reverse to keep the light on while I load the boot?
Cheers,
Post #458968 29th Sep 2015 1:14pm
Stick it in reverse in the main box, neutral in the transfer box, and leave the engine running. Make sure of course that the handbrake is good though.
Remember that having a work light wired into the reverse circuit is technically illegal, and it is illegal to use a work light in a place to which the Road Traffic Acts apply (so public highway or "place to which the public has access") unless it is used in conjuction with a flashing warning beacon. That being said, I have never heard of anyone being hassled for either.
Post #458980 29th Sep 2015 2:05pm
Page 2 of 3 <123>
