![]() | Home > Puma (Tdci) > moto-lita on 07 puma |
BigGeorge Member Since: 08 Aug 2009 Location: Zurich Posts: 43 ![]() ![]() ![]() |
http://www.devon4x4.com/products_a/p1921c1...wheel.html
I fitted this one. It's not completely flat (compared to my former Momo steering wheel) but it's also not a deep dish style wheel! The steering wheel comes approx 1 inch closer to the driver. The indicator / wiper switch are therefore a bit further away from the wheel but you get used to it very quickly. It looks great and has just the right size/diameter. The smaller wheels are partially blocking the view to the dashboard . That is especially the case with taller people. Regards George The goons are trying to bring me down! Defender 110 SW MY10 useless piece of ![]() Defender 90 V8 50th Anniversary Series IIa 109 / 6 cyl. ex-fire truck |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
I looked into this and contacted Moto-Lita direct.. they say there is a bit of a lottery regarding the spline configuration and advised to remove current wheel then count the splines. Land Rover say they do vary even in the same year build... Then i hear you have to turn the boss down a bit in a lathe to allow flush fitting and indicator cancelling.. so i never bothered and kept the XS leather one as fitted. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 ![]() ![]() ![]() |
Here is all the stuff on splines and what boss you need
http://www.mudstuff.co.uk/moto_lita_steering_wheel.shtml NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
I have liked the look of the Moto-Lita steering wheels for some time and like Portafilter was unsure what combination to go for, flat, dish, 14", 15" polished, teardrop, slot etc. etc.
I looked at various sites including Moto-Lita themselves and decided as Thruxton was not too far out of my way to turn up unannounced at their premises to see what they could do for me and maybe see what suits best!!! Bit hard to find as sign on unit was hidden behind tree Doh!!! ![]() Explained I wanted shot of this for something more aesthetically pleasing... ![]() They explained that they didn't normally have callers 'dropping in on a whim' to buy a steering wheel and that they were uninsured to change steering wheels but provided me with the tools to remove mine so splines could be counted to ascertain what boss I needed...48 spline for me needed! YOU NEED TO COUNT YOURS TO MAKE SURE BEFORE ORDERING! (See Fekete's explanatory link on previous post). ![]() They didn't have a polished boss in stock so they generously spent 20 minutes polishing one up for me. ![]()
Red Dot you heard wrong me old mucker....This is definately NOT the case as mine cancel fine and the wheel also sits fine and dandy. ![]() End result.... ![]() ![]() Portafilter I wanted pretty much the same as you a wheel that would sit more or less the same distance etc. from the stalks and not to lose visibility of any of my instruments...15" flat is a good choice for exactly those reasons! 14" and you lose visibility of rpm from the ten o clock to twelve o clock positions and speed from twelve o clock to two o clock positions approximately! Hope this helps. ![]() ![]() ![]() On way home found a village that was throwing a party in my honour...think I may have read it wrong but took a photo anyway... ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
Looks nice Mal still the size of a bus wheel tho
![]() What class are you in in the K9 event ![]() ![]() ![]() ![]() |
![]() ![]() Yeah I know I kept it standard size but 'big is beautiful' Karlos, you should know that already! ![]() In answer to your second question 'Big sharp teeth and balls the size of watermellon class! Grrrrrr ![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5082 ![]() ![]() ![]() |
Just a question...and not trying to be a kill joy...is there any advantage to these wheels??! because is it only me that thinks they look awful
![]() Incidently - this isnt a comment for you having one, if you like it...enjoy Mike |
Well Malcolm.....I think it looks fine it matches your door handles your wheel nuts and your back silver bits on the back of your cross member....Don't know the name of them
![]() ![]() ![]() These bits ![]() Click image to enlarge NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
Mike,
Absolutely no advantage of having such a steering wheel at all! As an engineer I like things that are beautifully engineered and crafted as in this case! Many of my extras serve no purpose whatsoever but the opportunity to individualise your vehicle. Some may like what you have done and some may not! In your case you obviously don't like the steering wheel, it matters not, and no offence has been taken! ![]() I am sorry my steering wheel is not to your liking, if you have a standard one fitted I don't like yours either! ![]() Ask yourself this in our eyes 'Why do women wear makeup?' Bling bling! If you got it flaunt it! I obviously haven't! ![]() ![]() Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 11th Sep 2010 11:52am. Edited 1 time in total |
Why not bling it up - i dont see anything wrong with that
![]() I suppose i like things that look like they should be there Mike |
I like it but i would have gone for the black version to blend in and not distract... but hey.... NICE! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Mike,
The wheel matches my aluminium billet door handles..were it not for the fact a pair of SVX aluminium difflock and gear change knobs cost �1000 I'd have them too, but sense and sensibility must prevail! As mentioned I got a significant discount on my purchase. I agree it may not look ideally suited to it's surroundings but I'm slowly getting there! On a lighter note my missus couldn't believe she spent so much money on the handles as a present for them to be fitted inside where nobody could see them! ![]() Thanks for the comments Red Dot! ![]() Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 11th Sep 2010 11:54am. Edited 1 time in total |
Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 813 ![]() ![]() ![]() |
But the 15" Moto wheel is still a touch smaller diameter than the standard, no? And if that is the case, is it enough to notice a little less trouser-rub, as it were? I think they look good, my only concern is that they offer less skull protection than the standard padded one, both in the centre, and the (top part of the) rim. |
Ads,
You are 100% right about the increased risk to your noggin in an accident! But hey life's a risk...isn't that one of the very many reasons Defenders are no longer sold in the US? Your reasoning crossed my mind within half an hour of driving and having it fitted! ![]() Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 11th Sep 2010 11:55am. Edited 1 time in total |
