Home > Wheels & Tyres > Bowler Wheels & Tyre Sizes (265 vs 285)
TheJollyBodger
Hi All,
Had a look through the forum and haven't really got a definitive answer to my question so....
I've got a black 2015 Puma '90 that I'm starting the add bits to.
I'm awaiting delivery of some Anthracite 18" Bowler wheels and I'm looking to source some tyres.
I like the BFG's AT KO's however I'm unsure on what width I should get.
Do people have an opinion on which tyre to get? (265's vs 285's)
If it helps, the defender will rarely go off road, however I do tow a heavy caravan. Possibly looking at lowering an inch may be two depending on hoe the car sits after fitting the wheels.
Post #446576 16th Aug 2015 7:55pm
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
You may need spacers for the 285s depending on the height i.e.75 as it may foul the radius arms although adjusting the lock-stop could prevent this. 285/75s give additional height of about 15mm over the 265/75s so if your are thinking of lowering the suspension then it would make sense to go for the 265s. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #446702 17th Aug 2015 8:09am
We have Bowlers on our 90 fitted with 265's with no problems at all, pictures in our Bowler threads
Post #446704 17th Aug 2015 8:16am
TJ101
Similar thread http://www.defender2.net/forum/topic37363.html
Mine is fine on 18" Bowler and 285 plus towing
 California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #446706 17th Aug 2015 8:25am
K9F
Do you know what offset the wheels have? I have 8" wide rims and as a result of the offset can run with 305 BFG KM2s tyres on standard suspension with no fouling issues whatsoever. There are tyre calculators about and basically you can enter your current size and have a play changing rims etc. Ideally try to retain the same or as close to the same rolling radius as standard. As mentioned offset may limit the width. The 285s over 265s give an overall difference in height of 30mm, speedo errors are also shown in the chart below.
As an example over standard tyres fitted to Boost wheels the 285s ON 18" Bowlers will increase the wheel height by 3.1" and make your speedo under-read by approximately 10%. The latter I believe can be recalibrated by a Nanocom if you wish.
http://www.dakota-truck.net/tirecalc/tirecalc.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #446707 17th Aug 2015 8:27am
LR Sam
TJ101 yours is a 110 which can take the wider tyre, I went 265's on mine with no problem but I have a friend who went 285 and catches on the inner rear wheel arch when towing with a 90. Hope that helps
Post #446717 17th Aug 2015 9:39am
TheJollyBodger
Great stuff,
Thanks for your input - I'll go down the 265 route. I'll post photos when done.
Lee
Post #446789 17th Aug 2015 1:36pm
TheJollyBodger
Hi,
Went down the 265 route - glad I did Smile
Post #449202 25th Aug 2015 8:15pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
We need pictures Wink
Edit. Dumb ass phone picked up the signal and I can now see you already have. Looks mint
Post #449205 25th Aug 2015 8:23pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
They look flippin nice, I wish I had deeper pockets Big Cry
Post #449209 25th Aug 2015 8:27pm
TheJollyBodger
I've been eating Beans on toast for the last 3 months Smile Glad I did - it looks ace!
Post #449213 25th Aug 2015 8:42pm
Lambley
You can afford beans AND toast?!!
Very nice looking 90 mate.
Post #449222 25th Aug 2015 9:01pm
Fellrunner
 2015 Defender 110 Puma 2.2 SW Corris Grey
They look great
Post #449560 26th Aug 2015 9:48pm
RRUK
I thought all newer Defenders had the bonnet letters "DEFENDER" instead of Land Rover as per the older vehicles?
Looks lovely by the way. 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #449642 27th Aug 2015 9:47am
AndrewS
FYI
Bowler 18's with 285 Cooper ST Maxx
 130's have feeling's as well you know Smile
Post #449645 27th Aug 2015 9:54am
