![]() | Home > Wheels & Tyres > Bowler Wheels & Tyre Sizes (265 vs 285) |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
You may need spacers for the 285s depending on the height i.e.75 as it may foul the radius arms although adjusting the lock-stop could prevent this. 285/75s give additional height of about 15mm over the 265/75s so if your are thinking of lowering the suspension then it would make sense to go for the 265s. Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
We have Bowlers on our 90 fitted with 265's with no problems at all, pictures in our Bowler threads
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
Similar thread http://www.defender2.net/forum/topic37363.html
Mine is fine on 18" Bowler and 285 plus towing ![]() Click image to enlarge California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
Do you know what offset the wheels have? I have 8" wide rims and as a result of the offset can run with 305 BFG KM2s tyres on standard suspension with no fouling issues whatsoever. There are tyre calculators about and basically you can enter your current size and have a play changing rims etc. Ideally try to retain the same or as close to the same rolling radius as standard. As mentioned offset may limit the width. The 285s over 265s give an overall difference in height of 30mm, speedo errors are also shown in the chart below.
As an example over standard tyres fitted to Boost wheels the 285s ON 18" Bowlers will increase the wheel height by 3.1" and make your speedo under-read by approximately 10%. The latter I believe can be recalibrated by a Nanocom if you wish. http://www.dakota-truck.net/tirecalc/tirecalc.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
LR Sam Member Since: 08 Nov 2012 Location: Yorkshire Posts: 235 ![]() ![]() |
TJ101 yours is a 110 which can take the wider tyre, I went 265's on mine with no problem but I have a friend who went 285 and catches on the inner rear wheel arch when towing with a 90. Hope that helps
TheJollyBodger Member Since: 27 May 2015 Location: Ramsbottom Posts: 74 ![]() ![]() ![]() |
Great stuff,
Thanks for your input - I'll go down the 265 route. I'll post photos when done. Cheers Lee |
Hi,
Went down the 265 route - glad I did ![]() ![]() Click image to enlarge ![]() Click image to enlarge |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 ![]() ![]() ![]() |
We need pictures
![]() Edit. Dumb ass phone picked up the signal and I can now see you already have. Looks mint Last edited by gazman on 25th Aug 2015 8:34pm. Edited 1 time in total |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 ![]() ![]() ![]() |
They look flippin nice, I wish I had deeper pockets
I've been eating Beans on toast for the last 3 months
You can afford beans AND toast?!!
Very nice looking 90 mate. |
Fellrunner Member Since: 28 Sep 2014 Location: Wandering Posts: 258 ![]() ![]() ![]() |
They look great
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 ![]() ![]() |
I thought all newer Defenders had the bonnet letters "DEFENDER" instead of Land Rover as per the older vehicles?
Looks lovely by the way. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
FYI
Bowler 18's with 285 Cooper ST Maxx ![]() Click image to enlarge 130's have feeling's as well you know ![]() |
