Home > Wheels & Tyres > Wheel offset |
How it will look will also depend on wheel width and tyre size....There are countless options, looks and functionality....For starters....
10" width wheel, 40mm offset and a 11.5" width tyre on a 15" wheel... Click image to enlarge Them wheels are Mach 5's if you want to achieve the same/similar look with 16 x 8 wheels ZU do a 38mm offset in that size. Mach 5s are like hen's teeth and are made of steel. ZUs are alloy but with a similar look. Modulars are your cheapest option obviously. http://www.johncraddockltd.co.uk/products/...and_is.php Mine nearest on Mach 5s, Fekete's behind on modulars. You could also 'pm' him for advice! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
27th Aug 2010 2:27pm |
peterl Member Since: 08 Jan 2009 Location: Pembrokeshire Posts: 308 |
Thanks, looking to stay with the 16", so will have a look at the ZU's to start with.
Any other ideas / options from anyone. |
28th Aug 2010 4:33pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Here is mine on 10/15 modulars with 33/12.50/15 cooper STTs
Click image to enlarge NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
29th Aug 2010 7:28am |
