Home > Wheels & Tyres > Wheel offset
peterl
1987 Defender 90 300 Tdi HT Epsom Green
Wheel offset
Looking to replace the standard LR boosts for a wheel with a greater off set in order to improve the turning circle on the 110 and better looks. Tyres are 265 x 75 x 16 fitment which I want to keep.
Any ideas and examples (pictures would be good)
Post #39219 27th Aug 2010 2:06pm
K9F
How it will look will also depend on wheel width and tyre size....There are countless options, looks and functionality....For starters....
10" width wheel, 40mm offset and a 11.5" width tyre on a 15" wheel...
Them wheels are Mach 5's if you want to achieve the same/similar look with 16 x 8 wheels ZU do a 38mm offset in that size. Mach 5s are like hen's teeth and are made of steel. ZUs are alloy but with a similar look. Modulars are your cheapest option obviously.
http://www.johncraddockltd.co.uk/products/...and_is.php
Mine nearest on Mach 5s, Fekete's behind on modulars. You could also 'pm' him for advice! Thumbs Up
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #39224 27th Aug 2010 2:27pm
peterl
Thanks, looking to stay with the 16", so will have a look at the ZU's to start with.
Any other ideas / options from anyone.
Post #39272 28th Aug 2010 4:33pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Here is mine on 10/15 modulars with 33/12.50/15 cooper STTs
 NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #39284 29th Aug 2010 7:28am
