Home > Puma (Tdci) > Busted Bearing and what else....?
Page 2 of 3 <123>
newhue
Australia
Common guys, if the stub is of a better quality purchase, and Timken bearings are used then all things should be still equal. The single nut and spacer isn't a bad option, just place it in there and crank the hell out of it. My thinking is if the bearing broke down due to over or under tension, it would have happened at a much lower kilometre range. Faulty case hardening, made in China, lack of grease or some contaminate were more likely the cause. My Defender and travels
Post #459074 29th Sep 2015 7:05pm
The single nut with spacer is a better (and cheaper) option if you have an unskilled person assembling the hub with access to all the different sizes of spacer, ie in a factory environment, since it de-skills the assembly task. All that is required is to follow a procedure (assemble, measure, dismantle, select spacer, reassemble, check , secure) with no judgement required by the assembler.
The two nut, no spacer arrangement is better if you have either a skilled person capable of applying judgement, or you have do not have access to a full range of (relatively expensive) spacers.
From a purely engineering standpoint both are of equal merit and equally satisfactory.
Post #459141 29th Sep 2015 9:38pm
newhue
Australia
Im wondering from an accountans point of view, if putting a spacer in, checking it, maybe changing for another, checking it. And possibily doing it all again would not be the most eficient way of doing it. If unskilled people are fitting something with pretty important tollerances and possible outcome than it has to be pretty fool proof.
On a side not, Roll Royce once upon a time had a lad sit there fitting cast pistons to block sizes. It was a slow process and every engine had all sorts of sizes in it. The Ford motor company introduced better machinging and accuracy to RR, and rest is history. Thank god the Merlin motor was born. My Defender and travels
Post #459160 30th Sep 2015 12:57am
brayn
Switzerland 2007 Defender 90 Puma 2.4 SW Java Black
Well I'm figuring I'll have a go at the two nut method as I can't get the spacer off... (Can't be bothered trying to be honest) And as it turns out, the outer bearing case wiggles a bit in the hub so the hub is toast too... Big Cry
So another internet order, some more customs fees and another afternoon working from home to wait for the super convenient delivery company and I'll finally be able to attack the reassembly job.
I ended up ordering some new discs and pads, as I figure the whole lot is off , would be a right #$@&% of a thing if I resemble and then find there's a problem/warpage with discs too... Caliper seems fine... But the ABS warning was on after the bearing blow out. That could have been due to hub wobble on its own. Anyway if I don't need them, they'll come on handy down the road.
Just got standard Lockheed stuff as I figure it worked before, and I have to take the truck in for an MOT equivalent test before year end so best bet is OEM...
Hopefully I'll be on the job next week.
Post #459330 30th Sep 2015 5:28pm
newhue
Australia
yeh the joy of working on a Land Rover soon becomes ho hum when you wait a week for parts, and even worse if you see the courier drive off without even attempting drop the parts off because they figure your not home.
Forget my mention of refurbing or cleaning the whole diff. I forgot you have the inner oil seal which will keep any muck on the outer side of it. I run my whole set up in oil.
make sure you seat the hub seal RTC3511 well. It sits about 3 or 4 mm into the casting. If you seat it flush it all works and feels right, but only for a limited time. I can guarantee that. Rolling Eyes My Defender and travels
Post #459347 30th Sep 2015 6:41pm
Top tip for seating the hub oil seal correctly: take the drive flange and use the side that normally faces the axle to drive the seal into tbe hub. The locating lip on the flange is (a) exactly the right thickness to push the seal to the right depth in the hub, and (b) exactly the right diameter to avoid damage to the outer lip of the seal. Using this technique you will locate the seal at the correct depth and perfectly square in the bore of the hub every time.
If you set out to design a special tool for the job you couldn't do better!
Post #459412 30th Sep 2015 9:31pm
Merlin
So what is the torque on the cover bolts? Not too tight seems a bit loose (no pun intended).
Merlin
Post #463749 16th Oct 2015 10:42am
Sorry, which "cover" do you mean?
Post #463773 16th Oct 2015 11:50am
Toplink
Driving flange bolts 65nm( no loctiite or spring washers needed).
Big stake nut/hub nut 210nm.
Hope this helps gen or oem parts all the way. Its never over in my land rover.
2007 Defender HTop.
1952 Series One 80"
1977 Muir-Hill 111.
2014 Triumph Tiger800xc
1999 Discovery 2 td5
1982 Ransomes TSR300D.
2002 Yamaha XT600e.
2010 Freelander2 (the wifes)
2008 John Deere X140
Post #464118 17th Oct 2015 6:21pm
Td5
Finland 1996 Defender 90 300 Tdi CSW Coniston Green
As "newhue" mention, use seal RTC3511, not the new FTC4785 (I'm not 100% sure about this number)
RTC3511 has double lip and springs in seal, FTC4785 is the new model that has no springs and is more
for tarmac. RTC3511 is the "old style" seal that at least in my Defender can handle hood deep wading.
You might also consider always purchasing either original or OEM seals, like Corteco, I have found some
bad, but only marginally cheaper seal on the market. Wrong place to save. My humble opinion.
Remember to feel how warm the hub get after driving. You find a lot of advice if you Google how to adjust
the bearings, some OK, some bad. Brgds,
Juha
'96 300Tdi 90
'07 Puma 90
Post #464380 18th Oct 2015 4:31pm
Merlin
Thanks for the torque setting. Does anyone know the part number of the inner seal? It's the one that keeps the diff oil from mixing with the bearing grease. In the diagram above it is item 9.
Merlin
Post #465011 20th Oct 2015 5:30pm
Martin
Site Admin
Part #9 is the RTC3511 / FTC4785 as mentioned above. (Bearing to outside world seal)
I think what you are after is FTC5268  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #465033 20th Oct 2015 6:27pm
Merlin
Post #465041 20th Oct 2015 6:39pm
aage
Iceland 2011 Defender 110 Puma 2.4 DCPU Alpine White
The flange bolts
You must remember to HEAT them up with a torch before unscrewing them, then the glue ( whatever its name ) will soften up and they wont brake during the extraction process. I watched my friend brake 2 on his car and they where really stuck and stiff all the way out. I heated mine up before unscrewing and NO PROBLEM at all, came out with ease. We bought our cars at the same time and they had about the same KM on the clock. http://www.defender2.net/gallery/index.php?cat=13451
Post #465120 20th Oct 2015 9:22pm
brayn
Evening all,
Just wanted to thank everyone for the help. Finished the job on the weekend employing the tricks you all imparted with me. I ended up changing discs, pads, bearings, one hub and one stub. The heat trick worked a treat on the non broken side (for the disc replacement, although my blow torch thing is a cheapo one and so it was a bit like a flame thrower at times Razz ), as did the drive flange seal application device... Hehe.
I've done 200km and no strange noise or adverse effects it seems. I'm not 100% convinced I got the pre-load right... (Perhaps I'm a worrier) I mean I followed the instructions and all... Just no real means of feed back so to speak... That said the wheel is still attached and there's no play, so I figure it should be good. I could rotate the hub, wouldn't say it moved 'freely' but it wasn't fighting back either...
Anyway, just wanted to show my appreciation...
Cheers all!
Post #467311 28th Oct 2015 3:50pm
Page 2 of 3 <123>
