Home > Maintenance & Modifications > Parts needed to replace front springs/shocks
Page 1 of 3 123>
excossack
What parts are needed to replace the front springs?
Other than the springs and shocks?
Looking at the parts catalogue:
The four spring plate retaining bolts
The nuts for the shocks
The nuts/washers that hold the spring turrent in place
The spring turret retaining ring (with what looks like captive bolts?)
Is that the lot 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #442620 3rd Aug 2015 8:37am
munch90
As a precaution yes , but if old ones undo then you dont need anything
only thing i would fit at same time are spring isolators on a 90 like these
eBay Item No. 261531397469
Post #442624 3rd Aug 2015 8:48am
Browny90
United Kingdom 2004 Defender 90 200 Tdi SW Stornoway Grey
Is that the lot
4 Springs
2 x Turret rings with 4x 8mm Nuts & Washers per ring (I believe they have a normal 8mm washer and a spring/lock washer)
2 x front shocks with Nuts & Bushes
2 x Rear Shocks with top bushes & Nuts and Bottom Bushes & Nuts
2 X Front spring retaining clamps with bolts, Nuts & washers
2 x rear spring retaining clamps with bolts & Nuts
you will probably be able to reuse the spring seats, but they do corrode.
The turret rings do have captive bolts, (If you're fitting dislocation cones you will need a set of rings with longer bolts..
Think that's everything.. My 1986 90 is currently on a full rebuild, with new chassis, Paint etc.. Very much a hybrid, TD5 Chassis, tub & bulkhead with a 200TDI and LT77 GB Painted in Stornoway Grey Smile 2 years off the road, but getting close to completion now
Post #442625 3rd Aug 2015 8:53am
excossack
Cheers chaps.
Rears are all done, so now just the front and normal service will be resumed!
I have all the bushes for the front shocks as well as the nuts.(at least I think I ordered them but will check)
For me standard shocks etc all round and no dislocation cones needed.
Thanks Munch90 - are these needed on a 110 and what do the do ?
I think the turret rings might be a good idea as the old ones I suspect are the original ones. 1999 Defender TD5 110
Regards
John M0VAZ
Post #442632 3rd Aug 2015 9:01am
munch90
The rings are ment to stop small vibrations transfer to the chassis/body
range rovers discoverys had them as standard
Post #442635 3rd Aug 2015 9:04am
excossack
Do they fit between the top of the spring and the underside of the top spring mount? 1999 Defender TD5 110
Regards
John M0VAZ
Post #442644 3rd Aug 2015 9:28am
munch90
yes at top
Post #442647 3rd Aug 2015 9:36am
excossack
Thumbs Up 1999 Defender TD5 110
Regards
John M0VAZ
Post #442648 3rd Aug 2015 9:37am
excossack
Are these only for the rear or fronts as well? 1999 Defender TD5 110
Regards
John M0VAZ
Post #442661 3rd Aug 2015 9:57am
munch90
I got them allround on a 90
Post #442662 3rd Aug 2015 9:59am
excossack
I had non on the 110 on the rear other than a rubber sleeve over the top couple of coils. 1999 Defender TD5 110
Regards
John M0VAZ
Post #442681 3rd Aug 2015 10:56am
munch90
don't come as stardard , I fitted them
the plastic coil on the spring is much the same thing , but cheap and crap as they normally split
Post #442683 3rd Aug 2015 10:59am
excossack
Ahh righty - cheers. 1999 Defender TD5 110
Regards
John M0VAZ
Post #442691 3rd Aug 2015 11:14am
Munch what are they made of? I'm assuming they last too.
Post #442696 3rd Aug 2015 11:25am
munch90
metal ring with hardish rubber bonded to them
ive always used them , never replaced one yet
Post #442709 3rd Aug 2015 11:46am
Page 1 of 3 123>
