![]() | Home > Maintenance & Modifications > Parts needed to replace front springs/shocks |
As a precaution yes , but if old ones undo then you dont need anything
only thing i would fit at same time are spring isolators on a 90 like these eBay Item No. 261531397469 Last edited by munch90 on 3rd Aug 2015 9:53am. Edited 1 time in total |
Browny90 Member Since: 20 Jul 2015 Location: Derbyshire Posts: 183 ![]() ![]() ![]() |
4 Springs 2 x Turret rings with 4x 8mm Nuts & Washers per ring (I believe they have a normal 8mm washer and a spring/lock washer) 2 x front shocks with Nuts & Bushes 2 x Rear Shocks with top bushes & Nuts and Bottom Bushes & Nuts 2 X Front spring retaining clamps with bolts, Nuts & washers 2 x rear spring retaining clamps with bolts & Nuts you will probably be able to reuse the spring seats, but they do corrode. The turret rings do have captive bolts, (If you're fitting dislocation cones you will need a set of rings with longer bolts.. Think that's everything.. My 1986 90 is currently on a full rebuild, with new chassis, Paint etc.. Very much a hybrid, TD5 Chassis, tub & bulkhead with a 200TDI and LT77 GB Painted in Stornoway Grey ![]() |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5933 ![]() ![]() ![]() |
Cheers chaps.
Rears are all done, so now just the front and normal service will be resumed! I have all the bushes for the front shocks as well as the nuts.(at least I think I ordered them but will check) For me standard shocks etc all round and no dislocation cones needed. Thanks Munch90 - are these needed on a 110 and what do the do ? I think the turret rings might be a good idea as the old ones I suspect are the original ones. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
The rings are ment to stop small vibrations transfer to the chassis/body
range rovers discoverys had them as standard |
Do they fit between the top of the spring and the underside of the top spring mount? 1999 Defender TD5 110
yes at top
![]() Regards John M0VAZ Econet Station 48 no clock |
Are these only for the rear or fronts as well? 1999 Defender TD5 110
I got them allround on a 90
I had non on the 110 on the rear other than a rubber sleeve over the top couple of coils. 1999 Defender TD5 110
don't come as stardard , I fitted them
the plastic coil on the spring is much the same thing , but cheap and crap as they normally split |
Ahh righty - cheers. 1999 Defender TD5 110
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20745 ![]() ![]() |
Munch what are they made of? I'm assuming they last too.
metal ring with hardish rubber bonded to them
ive always used them , never replaced one yet |
