Home > Maintenance & Modifications > Front door alignment question
Page 2 of 2 <12
You might find it is worth checking for wear in the hinges while you're at it. Some people find that the hinge pins wear at an accelerated rate (especially if not lubricated occasionally) and I have seen a hinge pin fail completely resulting in the door flapping about in a dangerous manner.
With the door open a couple of inches, try lifting the outer edge of the door. If the hinges are worn you will get an obvious movement of the door, and you can see which hinge is the worn one (or if both are worn).
Post #441882 31st Jul 2015 11:01am
AndyTunn
New Zealand 2008 Defender 90 Puma 2.4 SW Stornoway Grey
Sorted! Here's a before'n'after shot...
Carefully loosened the A-pillar bolts, repositioned the door (including moving the stricker) and re-tightened everything. Will probably have 10 more leaks now than it had before, but that's life with a Defender! Laughing
Thank you to all those who posted tips and advice. Thumbs Up
Post #442085 1st Aug 2015 4:30am
Page 2 of 2 <12
