![]() | Home > 130 > The bane of her life. |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1593 ![]() ![]() ![]() |
Is that a brooklands Range Rover?
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10383 ![]() ![]() |
I'm lucky...my missus set up a direct debit to part fund my project
![]() ![]() I love a 130, keep the thread going ![]() |
Rosso_NI Member Since: 09 May 2014 Location: NI Posts: 275 ![]() ![]() ![]() |
Hi Chris
About time ![]() |
tonyhedge Member Since: 07 Jul 2015 Location: Worcestershire Posts: 101 ![]() ![]() |
Either you've got an electric heater in the garage, or you are rebuilding it in the dining room.
When I were a lad ... That's not a dent, it's a rivet. That's not a dent, it's a rivet. That's not ... oh! That is a dent! 2014 90 XS SW 1997 Discovery 300TdiS (retired to stud) 1966 Series IIA 88" (now my son's) 2001 Astra - I need something to go and buy the parts when the others are off the road! |
MuddyChris300tdi Member Since: 02 Mar 2014 Location: Derby Posts: 224 ![]() ![]() ![]() |
Thanks, it's my mate's Range Rover,
![]() Click image to enlarge 4.6 did us proud, up to Perth and back in a day through rain snow and ice without a hitch. We had a few brown pants moments, hitting black ice on a bend and nearly putting us through a stone wall on the way up.having a flat tyre and a blow out on the trailer on the way back down. It's currently at another mate's, (in his garage) having all the welding done along with needing new brake lines, a frame ball joint, prop uj's, o and gearbox. Will probably find more on the way. |
Fantastic looking truck
![]() I would love a Tdi 130 but they are very rare beasts as most of them are still out being used! Keep us posted ![]() Self confessed mileage hunter ![]() |
fathaggis Member Since: 31 May 2015 Location: taynuilt Posts: 385 ![]() ![]() |
nice bus matet. I would also love one .........my 90 is 2 small now
So all welding is now done. While i have the tub of im going to give the chassis a good lick of paint.
We now onto brake lines, full set front to back and the calipers have seen better days so replacing them too. |
Keep the tread going...pics help
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 ![]() ![]() ![]() |
130 appreciation society
![]() 1995 110 300TDI 1995 90 300TDI |
I had been given a reconditioned caliper for the Salisbury axel so was going to see what options I had a paddocks. Well just got back and the options were Brit part or AP. So that will be two new AP calipers going on.
While I was taking the calipers of the other night I flipped the hub flange cap off to find that the flange and half shaft had been welded together. It was a very nice weld but it had cracked. So two new half shafts and flanges also to go on. I will try and get some pictures up later. |
I few pictures to update.
Back end of the chassis has had a few coats of paint now to all the bits I will struggle to do get to once tub is on. ![]() Click image to enlarge I bolted the new brake calipers on and the pulled out the the welded drive flange and half shaft. ![]() Click image to enlarge To find the stub axel oil seal had gone so all came off to replace it. I took the opportunity to pull the diff pan off to make sure all is good there which it was. ![]() Click image to enlarge It's all back together now with new brake lines to the back. We are now on to the front end which again needs brake lines and calipers. It also needs discs but I need to decide what to go for. |
Gearbox now ordered with hd bearings and v8 5th gear. Having her on the road is getting closer.
Great news, it past the mot yesterday. A big step in the right direction. Now just to drop the gearbox out and pick up my new one. And do a few other little bits. Bonnet won't latch fully, wipers are painfully slow, and I won't to get it painted/sealed up underneath.
