Home > 130 > The bane of her life. |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1588 |
Is that a brooklands Range Rover?
15th Jul 2015 11:02pm |
I'm lucky...my missus set up a direct debit to part fund my project I've rummaged through a large stockpile of women to get there though!!!! They are out there
I love a 130, keep the thread going |
16th Jul 2015 7:36am |
Rosso_NI Member Since: 09 May 2014 Location: NI Posts: 275 |
Hi Chris
About time liking the thread title, applies to my household as well. Looking forward to seeing your updates and progress. 1993 Defender 110 Ex Military soft top, with a long wishlist already |
16th Jul 2015 7:56pm |
tonyhedge Member Since: 07 Jul 2015 Location: Worcestershire Posts: 101 |
Either you've got an electric heater in the garage, or you are rebuilding it in the dining room.
When I were a lad ... That's not a dent, it's a rivet. That's not a dent, it's a rivet. That's not ... oh! That is a dent! 2014 90 XS SW 1997 Discovery 300TdiS (retired to stud) 1966 Series IIA 88" (now my son's) 2001 Astra - I need something to go and buy the parts when the others are off the road! |
16th Jul 2015 8:01pm |
MuddyChris300tdi Member Since: 02 Mar 2014 Location: Derby Posts: 224 |
Thanks, it's my mate's Range Rover,
Click image to enlarge 4.6 did us proud, up to Perth and back in a day through rain snow and ice without a hitch. We had a few brown pants moments, hitting black ice on a bend and nearly putting us through a stone wall on the way up.having a flat tyre and a blow out on the trailer on the way back down. It's currently at another mate's, (in his garage) having all the welding done along with needing new brake lines, a frame ball joint, prop uj's, o and gearbox. Will probably find more on the way. |
16th Jul 2015 9:13pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
Fantastic looking truck
I would love a Tdi 130 but they are very rare beasts as most of them are still out being used! Keep us posted Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
17th Jul 2015 12:24pm |
fathaggis Member Since: 31 May 2015 Location: taynuilt Posts: 385 |
nice bus matet. I would also love one .........my 90 is 2 small now
17th Jul 2015 12:36pm |
So all welding is now done. While i have the tub of im going to give the chassis a good lick of paint.
We now onto brake lines, full set front to back and the calipers have seen better days so replacing them too. |
22nd Aug 2015 6:40am |
Keep the tread going...pics help
22nd Aug 2015 6:45am |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 |
130 appreciation society 1951 80" S1 2.0
22nd Aug 2015 9:04am |
I had been given a reconditioned caliper for the Salisbury axel so was going to see what options I had a paddocks. Well just got back and the options were Brit part or AP. So that will be two new AP calipers going on.
While I was taking the calipers of the other night I flipped the hub flange cap off to find that the flange and half shaft had been welded together. It was a very nice weld but it had cracked. So two new half shafts and flanges also to go on. I will try and get some pictures up later. |
22nd Aug 2015 10:25am |
I few pictures to update.
Back end of the chassis has had a few coats of paint now to all the bits I will struggle to do get to once tub is on. Click image to enlarge I bolted the new brake calipers on and the pulled out the the welded drive flange and half shaft. Click image to enlarge To find the stub axel oil seal had gone so all came off to replace it. I took the opportunity to pull the diff pan off to make sure all is good there which it was. Click image to enlarge It's all back together now with new brake lines to the back. We are now on to the front end which again needs brake lines and calipers. It also needs discs but I need to decide what to go for. |
12th Sep 2015 8:26am |
Gearbox now ordered with hd bearings and v8 5th gear. Having her on the road is getting closer.
25th Sep 2015 6:02pm |
Great news, it past the mot yesterday. A big step in the right direction. Now just to drop the gearbox out and pick up my new one. And do a few other little bits. Bonnet won't latch fully, wipers are painfully slow, and I won't to get it painted/sealed up underneath.
22nd Oct 2015 7:06am |
