Home > Td5 > Extra Whistling noise
charliebaja
United Kingdom 2002 Defender 110 Td5 CSW Zermatt Silver
I have noticed an extra whistling noise on boost from the front end of my TD5. The engine is modified and has been fine since i had it done about 2 years ago. It was all working fine until on the way back from Wales and I noticed the extra noise. I feel that there isnt a loss of power however now and then it feels there might be a splutter.
Any suggestions, Oh and i have checked to pipes and manifold and cant see any black soot.
Post #429347 7th Jun 2015 9:40pm
Clive
Have you replaced the air filter recently, I did this a couple of weeks back, found I hadn't clipped the back edge of the filter box lid in properly on one corner, so it was sucking in air through the gap when under boost.
Otherwise, maybe a split/crack in the intercooler somewhere?
Post #429409 8th Jun 2015 7:55am
Dpgdefenders
Check none of the exhaust manifold to head studs have not sheared off.
Post #433468 24th Jun 2015 10:11pm
michaelwl
South Africa 2002 Defender 110 Td5 SW Alpine White
I had a similar noise and thought I had checked the pipes properly but obviously not, because about 500Km later the pipe popped off from the intercooler and on refitting correctly the whistling had gone. 2002 110 TD5 White
1981 S3 R6 Matt Green - Now used as game viewer
2013 Discovery 4 XS
Post #433519 25th Jun 2015 8:08am
charliebaja
So the whistling now happens a lot more frequently and there is a certain lack of power at lower revs, funnily still gets to 95mph though!!
I cant see an soot deposits around the manifold and if i rev it when warm at stand still i can hear the extra whistle.
Any ideas?
Post #441124 28th Jul 2015 5:58pm
My first suspicion would be a warped exhaust manifold, especially if the engine has been tuned. A common problem.
Post #441127 28th Jul 2015 6:02pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
As said above, check intercooler, pipe work, etc.
Lack of power is a big symptom of leaking intercooler, and hoses. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #441128 28th Jul 2015 6:03pm
charliebaja
The issue is I think coming from the engine area not at the front, and annoyingly I cannot see any kind of exhaust related soot release.
Post #441194 28th Jul 2015 9:14pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Blackwolf is right, it's probably a warped manifold that could have pulled a stud, not easy to see with the heatshield in place, look for sooty deposit around one of the 5 manifold outlets, also check the turbo gasket, I've got a skimmed and de-webbed manifold ready for mine, just not got around to fitting it.
On a tuned Td5 it's a regular problem, once a manifold has warped, get it skimmed flat and have the webs removed to give it more flex, then fit a better stud kit and refit. Another way to try and see the leak if it's not obvious is spray WD40 of similar around the manifold (cool engine) and watch for bubbles. Best of luck
Post #441238 29th Jul 2015 4:41am
jst
Assuming none of above, damaged turbo impeller? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #441245 29th Jul 2015 5:53am
RLD
Had that with mine Whistle RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Post #441353 29th Jul 2015 11:27am
I currently have this problem with my Disco2 - it whistles like an incoming ICBM when under acceleration.
Post #441372 29th Jul 2015 12:29pm
