Home > Technical > Badly worn drive shaft / flange
Page 3 of 4 <1234>
lohr500
Must admit I was surprised at how difficult the bolts were to undo and retighten. I put it down to the blue threadlock on them. A very different carry on to those on a series LR which from memory used spring washers. Am I correct in remembering that the thread holes went right through the casting and into the area which was bathed in oil on the earlier vehicles? After doing the first hub and piling all the bolts on a tray, I kept all the bolts in the same locations for the other three which seemed to make it easier to tighten them up. I can see how a bolt could get sheared off if care wasn't taken to ease them out or put them back in gently.
Post #418312 23rd Apr 2015 9:48am
Clive
I used an M10 x 1.5 tap to run through the hub threads to clean them up, then used new bolts with a dab of fresh Loctite on them, (torqued to 65Nm,) made re-assembly a less traumatic experience Thumbs Up
Post #418325 23rd Apr 2015 10:14am
Happyoldgit
While removal and greasing the splines is the ideal scenario I wonder if those with new or nearly new vehicles would be advised to pop the dust caps and circlips and run a bit of oil into the splines every now and again. Steve.
http://forums.lr4x4.com
Post #418341 23rd Apr 2015 11:08am
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
Grease would be better, no? If so, what grease?
Post #418345 23rd Apr 2015 11:31am
That's what I'm wondering if I can get away with, albeit with grease, or whether none with go down the splines and it will just end up everywhere else!
I'm reluctant to take the drive flange off without having a new gasket and set of bolts.
Post #418363 23rd Apr 2015 12:24pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
In your opinion what is the best way to bolt on the Flange ??
Loctite on the bolts and torque up
Or Spring washers under the bolt heads.
I tend to use spring washers as less chance of the bolt getting welded into the hub, find it easier to change the flange in years ( months ) to come.
Post #418369 23rd Apr 2015 12:52pm
Previously I've always used spring washers, but that was because my Lightweight came like that!
On another vehicle were the steel bolts were going into an aluminium housing, and it was safety critical, i.e. caliper mounting, then a liberal coating with a medium threadlock did the double job of holding them tight & separating the dissimilar metals.
On a puma, I think a little threadlock on the bolt threads wouldn't hurt.
Post #418373 23rd Apr 2015 1:18pm
munch90
as normal anything is better than nothing as a stop gap preventive measure !
Post #418385 23rd Apr 2015 1:44pm
The flange bolts are M10x45 grade 10.9. The bolts supplied by LR are preloaded with threadlocker.
I use hex socket head capscrews, which are widely available, the same grade, and much cheaper. I also use (good quality) spring washers not threadlocker, since the majority of breakages are caused by the holes becoming plugged with threadlocker and/or gasket compound.
There's no reason why you shouldn't use Hylomar instead of a gasket but take care not to get it in the bolt holes or on the threads.
The holes have always been blind, even on S1 vehicles.
Post #418409 23rd Apr 2015 3:40pm
Do you use new bolts each time?
Post #418430 23rd Apr 2015 5:35pm
No, why would you? They're not stretch bolts so provided they haven't been overtightened (use a torque wrench) they should last indefinitely. Thumbs Up
Post #418442 23rd Apr 2015 6:35pm
Workshop manual states fit new - just thought that it was odd.
Post #418470 23rd Apr 2015 8:36pm
MadTom
I think, recommendation to use new is because they have them prepared with a threadlocker. But use old screws, clean them and apply a "Loctite" is "the same". "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #418476 23rd Apr 2015 8:58pm
I can understand that - I think my main dealer charges labour at the equivalent of £1.90 per minute, so a couple of minutes cleaning a bolt x 2 soon adds up to more than the cost of new bolts!
Post #418607 24th Apr 2015 10:30am
zone30
Just a noob question:
Would it suffice to grease the bearings without removing them?
I have HD flanges laying around which I like to fit, but haven't found the courage yet due to not feeling informed enough yet.
If so, what grease? If not, just remove, grease and put back or always replace bearings?
It's my daily drive, so I can not afford taking stuff appart I cannot refit within one day/weekend, nor get stuck not having the wright tools or parts.
(Puma 2.4)
Post #421493 6th May 2015 9:02am
Page 3 of 4 <1234>
