Home > Puma (Tdci) > Air conditioning
Michael S
United Kingdom 2009 Defender 110 Puma 2.4 USW Tonga Green
Air conditioning
I'm not convinced my a/c is behaving as it should. If I get in and start it for the first time that day the a/c blows cold straight away even when ambient is nudging 30C. But if I drive somewhere and stop when I get back in it usually takes sometime to blow cold, perhaps upto 15 minutes.
The dealer say they can find no fault but it seems something is up to me. Anyone with ideas or similar problem?
Michael
Post #35986 10th Jul 2010 10:56pm
K9F
Nothing to lose popping along to these:
http://www.kwik-fit.com/about-air-conditioning.asp
Here is an extract:
" Recharge or No Charge"
Let Kwik Fit recharge your Air Con while-u-wait. We will replace and recharge lubricant and refrigerant levels in line with your manufacturer’s recommendation. If we cannot improve the coolest vent temperature from your car by more than 10% when measured in degrees Celsius - then you pay nothing at all.*
As said absolutely nowt to lose except maybe an hour of your time! Dog Thumbs Up Dog If you go through life with your head in the sand....all people will see is an ar5e!!
Post #35993 11th Jul 2010 7:51am
NoDo$h
Won't be a refridgerant issue - it's likely to be the a/c clutch or temp sensors giving anomylous readings. Don't trust your car to KwikFit!
54 Freelander modded for mud
2008 D3 SE
2010 90 XS SW
1978 88 Series 3 undergoing surgery with a new owner
2007 90 County Truck Cab - gone
2006 D3 SE - gone
2004 Freelander Sport - gay
1999 Disco V8 ES rotted to bits
Post #35995 11th Jul 2010 8:55am
nickhodgson
There are a few things to check. Is your compressor coming on? and is the compressor cycling (going on and off).
When the compressor is on the pipe coming from the bulkhead (behind ECU) should be cold. The compressor should cycle. If it just stays on then I would suspect your de-ice switch.
Report back,
Nick
Post #35996 11th Jul 2010 8:55am
Michael S
When it works it works normally but on the occasions it chooses not to the compressor isn't cutting in. My feeling is most likely one of the pressure or temperature sensors being faulty. It may even be over gassed but I can't see why and it wouldn't work the first time it's started on these 30C days if it was.
I wonder how much the ECU is involved in the a/c since the dealer service guy did mutter it could be related to earthing problems I've previously had that caused ECU related starting problems. They did say the electric fan in front of the radiator had jammed and thought they had cured the problem. Unfortunately it's another irritating intermittent fault that spoils an otherwise good vehicle. Could be time to read the riot act to the dealer again although they are much more helpful than when I bought my Td5 seven years ago.
Michael
Post #36006 11th Jul 2010 8:44pm
nickhodgson
The other thing to check is if your radiator restricted (mud?) is any way as the ECU will not start the aircon if the engine temp is too high.
Just to be sure when you say working normally you mean that the compressor is cycling?
Post #36010 12th Jul 2010 6:18am
NoDo$h
No, it's in the car. Whistle
2008 D3 SE
2010 90 XS SW
2006 D3 SE - gone
Post #36013 12th Jul 2010 7:06am
Michael S
Radiator clean and compressor cycling when working.
Perhaps I'll try and explain again the symptoms. Today we did an induction for our harvest workers visisting five farms with journeys between 1 and 12 miles and each time we stopped for typically five minutes when we got back in the a/c just blew ambient for a start but then kicked in a few miles/minutes up the road. All puzzling to me.
Michael
Post #36086 12th Jul 2010 11:00pm
nickhodgson
you could try another de-ice switch. You can get to the connector without removing the dash and connect a new switch. Hold the switch sensor on some ice and the compressor should cut out and then in air warmer then 3 degrees and it should cut in. Obviously dont let the compressor run for too long or things will freeze up.
The other option is that you have some water in your system that is freezing and blocking the expansion valve. Debris would also block the valve.
Post #36094 13th Jul 2010 6:17am
AndrewS
Is there water running from the AC drain Question 130's have feeling's as well you know Smile
Post #36220 13th Jul 2010 10:46pm
Michael S
Yes, lots when it chooses to come on. It seems not to want to work when the interior is hot. A couple of miles up the road with the windows open purging the hot air and away it goes for as longer journey as you like. But stop for say 5 or 10 minutes parked in the sun and a repeat performance - like waiting for your heater to come warm from a cold start but in reverse!
With harvest/combining upon us it may have to wait to go to the dealers till the autumn.
Michael
Post #36320 14th Jul 2010 9:07pm
