![]() | Home > Puma (Tdci) > Air conditioning |
Nothing to lose popping along to these:
http://www.kwik-fit.com/about-air-conditioning.asp Here is an extract: " Recharge or No Charge" Let Kwik Fit recharge your Air Con while-u-wait. We will replace and recharge lubricant and refrigerant levels in line with your manufacturer’s recommendation. If we cannot improve the coolest vent temperature from your car by more than 10% when measured in degrees Celsius - then you pay nothing at all.* As said absolutely nowt to lose except maybe an hour of your time! ![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 ![]() ![]() |
Won't be a refridgerant issue - it's likely to be the a/c clutch or temp sensors giving anomylous readings. Don't trust your car to KwikFit!
![]() 54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 ![]() ![]() |
There are a few things to check. Is your compressor coming on? and is the compressor cycling (going on and off).
When the compressor is on the pipe coming from the bulkhead (behind ECU) should be cold. The compressor should cycle. If it just stays on then I would suspect your de-ice switch. Report back, Cheers Nick |
Michael S Member Since: 12 Jan 2010 Location: In an Essex field Posts: 21 ![]() ![]() ![]() |
When it works it works normally but on the occasions it chooses not to the compressor isn't cutting in. My feeling is most likely one of the pressure or temperature sensors being faulty. It may even be over gassed but I can't see why and it wouldn't work the first time it's started on these 30C days if it was.
I wonder how much the ECU is involved in the a/c since the dealer service guy did mutter it could be related to earthing problems I've previously had that caused ECU related starting problems. They did say the electric fan in front of the radiator had jammed and thought they had cured the problem. Unfortunately it's another irritating intermittent fault that spoils an otherwise good vehicle. Could be time to read the riot act to the dealer again although they are much more helpful than when I bought my Td5 seven years ago. Michael |
The other thing to check is if your radiator restricted (mud?) is any way as the ECU will not start the aircon if the engine temp is too high.
Just to be sure when you say working normally you mean that the compressor is cycling? |
No, it's in the car.
![]() ![]() 54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
Radiator clean and compressor cycling when working. Perhaps I'll try and explain again the symptoms. Today we did an induction for our harvest workers visisting five farms with journeys between 1 and 12 miles and each time we stopped for typically five minutes when we got back in the a/c just blew ambient for a start but then kicked in a few miles/minutes up the road. All puzzling to me. Michael |
you could try another de-ice switch. You can get to the connector without removing the dash and connect a new switch. Hold the switch sensor on some ice and the compressor should cut out and then in air warmer then 3 degrees and it should cut in. Obviously dont let the compressor run for too long or things will freeze up.
The other option is that you have some water in your system that is freezing and blocking the expansion valve. Debris would also block the valve. |
Is there water running from the AC drain
Yes, lots when it chooses to come on. It seems not to want to work when the interior is hot. A couple of miles up the road with the windows open purging the hot air and away it goes for as longer journey as you like. But stop for say 5 or 10 minutes parked in the sun and a repeat performance - like waiting for your heater to come warm from a cold start but in reverse! With harvest/combining upon us it may have to wait to go to the dealers till the autumn. Michael |
