Home > Puma (Tdci) > Strange Problem, top speed 39mph after truck runs 1/2 hour
JBinAlabama
United States
I have a strange thing going on With my truck. After I've driven about 30 minutes, if I turn it off and then started back up the top speed is around 40 mph in sixth gear. He revs are very low and it has almost no power.
I've had to limp home a couple of times from this. When I started the next day no problem! I've checked all of the fuses as I have read that sometimes a blown fuse will cause a rev limit like it's in the low range.
When I drive shorter durations, like 15 or 20 minutes this does not happen.
Does anyone have a suggestion as to what this problem might be caused by?
Post #410201 23rd Mar 2015 5:00pm
Lorryman100
Do you have access to a diagnostic tool or a basic fault code reader? If so what dtc's are logged, what is the maximum MAP sensor reading and do the revs go over 2000rpm?
It could be a number of issues from fuel starvation through either a blockage or air lock to an electrical issue with the Turbo modulator, MAP sensor or accelerator potentiometer to an issue with a short in the engine harness. If you don't have access to a diagnostic tool remove the MAP sensor and give it a clean with carburettor cleaner and coat the electrical pins in contact cleaner. Next check the Turbo loom and plug connections for any breaks etc. also check the accelerator plug for the same issues and coat the plug pins in contact cleaner.
From the symptoms you describe it sounds as if there is an intermittent issue with boost pressure that only manifests itself once the engine gets hot. It could also be a leaking boost pipe that is sealed when cold but once the engine gets hot it is venting though this would throw on the MIL light as the expected readings from the Turbo and the MAP sensor would not match.
HTH Thumbs Up
Post #410248 23rd Mar 2015 6:46pm
dgardel
Italy
NEW Land Rover ECU fuel saving strategy Rolling with laughter Mr. Green Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #410251 23rd Mar 2015 6:54pm
NickH
England 2003 Defender 90 Td5 PU Rimini Red
As I mentioned in a post last week, It could be the thermostat.
If the engine gets too warm it will go into limp mode but there will be no warning lights.
When it cools down and the ignition is turned off and on again it will cancel it.
Sorry I cant be more help Thumbs Up 2003 Td5 90
2013 sport hse
2012 700 raptor quad
2012 siromer 4x4 tractor
Post #410281 23rd Mar 2015 8:24pm
martinfiattech
If I remember correctly, the l/r has the same engine ecu as transit.
If it over heats, it does not go in to limp mode. It just cuts out. their is a thermal cut out sensor on the back of the cylinder head. No 4 cylinder area.
This I found out by a customer replacing his fuel injection pump on a transit ( On the advice of another workshop). Then it came to me.
A good hunt round with an infra red thermometer, lead to a water pump impeller spinning on it`s shaft. Thus giving the over heating.
I`ve only had this fault a few times, all of which did not store a fault code. Excuse the spelling I`am better with spanners and wires.
Post #410378 23rd Mar 2015 10:47pm
JBinAlabama
United States
I'll have a check around and see if something Looks off using your insights.
Which diagnostic tool would you reccomend?
No dealers close to me at all.
Post #410415 24th Mar 2015 12:59am
What engine do you have?
Post #410465 24th Mar 2015 11:08am
JBinAlabama
United States
Tdci, 2.4
Post #410688 25th Mar 2015 12:04am
Cupboard
Regarding diagnostics, this thread is worth a read:
http://www.defender2.net/forum/topic10829.html
For a "does almost everything", I'd get a Nanocom, for a "does everything" a Faultmate.
YMMV.
How have you managed to get a 2.4 Puma in the States?
Post #410905 25th Mar 2015 8:34pm
AndyLloyd
England 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
Did you ever resolve this problem JB? Mine has the exact same symptons...sometimes....hahahah
Post #413504 3rd Apr 2015 2:46pm
JBinAlabama
United States
Funny enough, after checking all connections under the hood the problem was gone way back then.
I thought I posted it here but must have lost my connection before it logged.
I really appreciate all the advice
Anyway, it just returned so I. Need to buy a Faultmate YMMV.
Any suggestion on where to order?
Post #446640 16th Aug 2015 11:17pm
Mogboy
Australia 2007 Defender 110 Puma 2.4 SW Belize Green
Have you checked the fuel tank breather is not clogged? Could cut fuel feed after 30 mins running.
Post #447880 20th Aug 2015 11:00pm
