Home > Puma (Tdci) > Strange Problem, top speed 39mph after truck runs 1/2 hour |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Do you have access to a diagnostic tool or a basic fault code reader? If so what dtc's are logged, what is the maximum MAP sensor reading and do the revs go over 2000rpm?
It could be a number of issues from fuel starvation through either a blockage or air lock to an electrical issue with the Turbo modulator, MAP sensor or accelerator potentiometer to an issue with a short in the engine harness. If you don't have access to a diagnostic tool remove the MAP sensor and give it a clean with carburettor cleaner and coat the electrical pins in contact cleaner. Next check the Turbo loom and plug connections for any breaks etc. also check the accelerator plug for the same issues and coat the plug pins in contact cleaner. From the symptoms you describe it sounds as if there is an intermittent issue with boost pressure that only manifests itself once the engine gets hot. It could also be a leaking boost pipe that is sealed when cold but once the engine gets hot it is venting though this would throw on the MIL light as the expected readings from the Turbo and the MAP sensor would not match. HTH |
23rd Mar 2015 6:46pm |
NEW Land Rover ECU fuel saving strategy Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
23rd Mar 2015 6:54pm |
NickH Member Since: 02 Nov 2014 Location: Halifax Posts: 204 |
As I mentioned in a post last week, It could be the thermostat.
If the engine gets too warm it will go into limp mode but there will be no warning lights. When it cools down and the ignition is turned off and on again it will cancel it. Sorry I cant be more help 2003 Td5 90 2013 sport hse 2012 700 raptor quad 2012 siromer 4x4 tractor |
23rd Mar 2015 8:24pm |
martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422 |
If I remember correctly, the l/r has the same engine ecu as transit.
If it over heats, it does not go in to limp mode. It just cuts out. their is a thermal cut out sensor on the back of the cylinder head. No 4 cylinder area. This I found out by a customer replacing his fuel injection pump on a transit ( On the advice of another workshop). Then it came to me. A good hunt round with an infra red thermometer, lead to a water pump impeller spinning on it`s shaft. Thus giving the over heating. I`ve only had this fault a few times, all of which did not store a fault code. Excuse the spelling I`am better with spanners and wires. |
23rd Mar 2015 10:47pm |
JBinAlabama Member Since: 10 Mar 2011 Location: Alabama, USA Posts: 15 |
I'll have a check around and see if something Looks off using your insights.
Which diagnostic tool would you reccomend? No dealers close to me at all. |
24th Mar 2015 12:59am |
What engine do you have?
24th Mar 2015 11:08am |
Tdci, 2.4
25th Mar 2015 12:04am |
Regarding diagnostics, this thread is worth a read:
http://www.defender2.net/forum/topic10829.html For a "does almost everything", I'd get a Nanocom, for a "does everything" a Faultmate. YMMV. How have you managed to get a 2.4 Puma in the States? |
25th Mar 2015 8:34pm |
AndyLloyd Member Since: 03 Feb 2015 Location: South Cheshire Posts: 11 |
Did you ever resolve this problem JB? Mine has the exact same symptons...sometimes....hahahah
3rd Apr 2015 2:46pm |
Funny enough, after checking all connections under the hood the problem was gone way back then.
I thought I posted it here but must have lost my connection before it logged. I really appreciate all the advice Anyway, it just returned so I. Need to buy a Faultmate YMMV. Any suggestion on where to order? |
16th Aug 2015 11:17pm |
Mogboy Member Since: 22 May 2013 Location: Brisbane Posts: 31 |
Have you checked the fuel tank breather is not clogged? Could cut fuel feed after 30 mins running.
20th Aug 2015 11:00pm |
