Home > Puma (Tdci) > Help! turbo boost solenoid
Dartmoor defender
My 110 (2008/ puma engine) is loosing power and it appears to be the turbo boost solenoid. The following codes are coming up;
P0046
P0234
It is a nightmare as I have already replaced the turbo within the last two years. I am told that you cannot buy the turbo boost solenoid on its own.
Has anyone got any suggestions?
Neutral
Post #408035 16th Mar 2015 1:17pm
K9F
Call Pete at Bell Auto Services.
Why the big writing? Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #408037 16th Mar 2015 1:24pm
Lou Sparts
I like the big writing I can read it without my glasses on Thumbs Up 2005 Td5 90 XS
Steve
Post #408039 16th Mar 2015 1:27pm
Caterham
are you sure it's the solenoid and not the wiring to it - I believe there's repair harness - installation detailed by dargel IIRC.
Are you getting fault codes?
good luck.
Post #408052 16th Mar 2015 1:47pm
Lorryman100
Puma turbos have a modulator attached to the turbo housing. Modulator failures whilst not unheard of are not that common however wiring faults are. Given the age of your defender I would be checking that the turbo modulator loom has not been fractured due to the engine vibration and that all the connections are secure within the modulator harness plug (circled in below pic).
To assist in diagnosing your issue can you answer the following questions?
1. Are the DTC's you listed tested or untested
2. Does the MIL lamp illuminate when you have the low power
3. What about the live data from the engine, how much boost psi is being generated
4. When you say the Puma is losing power could you explain the symptoms
5. What makes you think it is the turbo
FYI
P0234 (Turbocharger A over boost condition) is a common dtc on Pumas.
Can you list the full DTC code for P0046 as there are 4 different faults under this dtc which can narrow down the electrical problem:
P0046-11 Turbocharger boost control A circuit range/performance- circuit short to ground
P0046-12 Turbocharger boost control A circuit range/performance - circuit short to battery
P0046-1A Turbocharger boost control A circuit range/performance - circuit resistance below threshold
P0046-1B Turbocharger boost control A circuit range/performance - circuit resistance above threshold
If the MIL is illuminated along with P0046 as a tested dtc then the issue is with the modulator, whether it is the modulator itself which is not a servicable part and if it is faulty a new turbo unit is required or the more likely issue is with the modulator harness, a break in the wiring or the plug contacts. JMTW Thumbs Up
Here is the Modulator wiring harness Tech Bulletin.
The modulator is No 3 in the below pic:
http://www.defender2.net/forum/topic9000.html
http://www.defender2.net/forum/topic8995.html
HTH :thumbsup:
Post #408271 16th Mar 2015 9:32pm
martinfiattech
Nice to see lorryman`s knowledge back. Will make a copy of these for myself, thanks.
I think I read some where you can get the turbo modulator unit it`s self, from ford separate to the turbo.
(Not saying that`s the problem. But have I got this wright ?). Excuse the spelling I`am better with spanners and wires.
Post #408344 17th Mar 2015 9:38am
Caterham
Talking 2.4's here.
Can anyone explain what the difference is between the earlier harness susceptible to problems and the later ones?
Post #429238 7th Jun 2015 3:10pm
ickle
I think the loom fails when it is stretched around the air con compressor.
In lorrymans post I would check the operation of the variable vanes first, carefully disconnect the link shown as item 4, and check they operate smoothly and don't stick.
Mines got the above codes and faults, changed the loom, sensors, ran 2 lots turbo cleaner through it with no joy, so now there's a brand new turbo on the bench waiting to fit
Post #429243 7th Jun 2015 3:21pm
Fifth Horseman
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
If my previous '07 was anything to go by, the harness to the actuator is quite tight with the wires under tension. On the later ones the loom has some slack in it.
Post #429244 7th Jun 2015 3:21pm
Caterham
Thumbs Up think mines the later variety
thanks.
Post #429405 8th Jun 2015 7:47am
lost gringo
Chile 2013 Defender 90 Puma 2.2 HT Baltic Blue
rotary actuators
these critters are available and cheap from aliexpress. but like the man said, they dont fail that often unless messed with
Post #717945 15th Jul 2018 9:30pm
lost gringo
with my icarsoft reader i get a code p2263 but it also shows Boost pressure actuator Bank 1 at .08% with desired position at 20%.
also Boost pressure actuator Bank 1 controller output is ALWAYS at 0%.
am i looking at a clue here?
forsure going to look closely at wiring loom, tho my actuator wires come below the ac compressor not over the top. guess they re-routed those 2013???
Post #718244 17th Jul 2018 5:12pm
