Home > Technical > Air filter |
Do you have an official K & N importer over there? If so that oil would do I would think! Alternatively e-mail ITG they may be able to advise! If you go through life with your head in the sand....all people will see is an ar5e!!
3rd Jul 2010 5:01pm |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2046 |
My ITG filter came pre-oiled
3rd Jul 2010 8:41pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5045 |
Dont use engine oil - it should be the correct oil, its not really an oil like that Mike
3rd Jul 2010 9:53pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2440 |
The bit it still on the sealed bag, but the oil looks quite thick actually. Puma 110" SW ............................................................. Earth first. Other planets later |
4th Jul 2010 12:46am |
JMS Member Since: 05 Mar 2010 Location: Isle of Wight Posts: 40 |
MK, Aerosol cans can be shipped by air but they would have to be IATA packed as they are classed as dangerous goods. If you want the ITG spay it can be done but i would suggest getting a few other bit to ship at the same time as the spay alone would be expensive. JMS |
4th Jul 2010 6:19am |
I think it is more of a 'machine oil' rather than engine oil thinner and with not so much viscosity. Jay's idea about about shipping by air seems a reasonable resolution. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
4th Jul 2010 7:46am |
I would agree that its more akin to machine oil than engine oil - but the genuine K&N is different still...im not talking about the fact its red Mike |
4th Jul 2010 3:38pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6312 |
Do you reckon WD40 would do the trick?
(I do - but then what do I know) I presume its more the fabric not the oil that does the filtering? |
18th Jul 2010 7:10pm |
I was adviced to use any air filter oil, such as for dirtbikes (sticky and thick). WD40 is too thin and would hurt your maf sensor Puma 110" SW
18th Jul 2010 7:42pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20561 |
Do they not come pre oiled ready for use?... Hence the sealed bag it's packed in?
17th Oct 2010 8:41pm |
sure! But you have to take it from the bag to use it Puma 110" SW
18th Oct 2010 5:27pm |
So what your saying is the bag is more oiled than the filter |
18th Oct 2010 6:34pm |
That was beginning of July? Has it sat in the bag at home for three and a half months? It's only a ten minute fit! Fit it and worry about the relube in a couple of years when and if it needs doing! If need be i'll source some for you and/or enquire about shipping it to you if it's possible by boat! There must be some way of getting you some??? What about Opie can they not help you out or advise? PM them! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
20th Oct 2010 1:43pm |
ummmm I invite you to run an engine oil test. In my case I do not drive it on foggy&wet tarmac roads for going to the mall, so I have to be careful about the air filter issue. Puma 110" SW
20th Oct 2010 1:56pm |
