Home > Technical > Air filter
MK
Air filter
Hi guys
I got my ITG foam air filter. Of course I could not import the spray (?) oil to replace after washing. Would a std engine oil do it?
thanks
MK Puma 110" SW
Post #35529 3rd Jul 2010 2:57pm
K9F
Do you have an official K & N importer over there? If so that oil would do I would think! Alternatively e-mail ITG they may be able to advise! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #35534 3rd Jul 2010 5:01pm
DAZ110
My ITG filter came pre-oiled
Post #35544 3rd Jul 2010 8:41pm
mse
Dont use engine oil - it should be the correct oil, its not really an oil like that Mike
Post #35548 3rd Jul 2010 9:53pm
MK
The bit it still on the sealed bag, but the oil looks quite thick actually. Puma 110" SW
Post #35551 4th Jul 2010 12:46am
JMS
England 2011 Defender 110 Puma 2.4 USW Stornoway Grey
Re: Air filter
MK wrote:
Hi guys
MK,
Aerosol cans can be shipped by air but they would have to be IATA packed as they are classed as dangerous goods. If you want the ITG spay it can be done but i would suggest getting a few other bit to ship at the same time as the spay alone would be expensive.
JMS
Post #35554 4th Jul 2010 6:19am
K9F
I think it is more of a 'machine oil' rather than engine oil thinner and with not so much viscosity. Jay's idea about about shipping by air seems a reasonable resolution. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #35556 4th Jul 2010 7:46am
mse
I would agree that its more akin to machine oil than engine oil - but the genuine K&N is different still...im not talking about the fact its red Rolling with laughter Mike
Post #35577 4th Jul 2010 3:38pm
Caterham
Do you reckon WD40 would do the trick?
(I do - but then what do I know) I presume its more the fabric not the oil that does the filtering?
Post #36534 18th Jul 2010 7:10pm
MK
I was adviced to use any air filter oil, such as for dirtbikes (sticky and thick). WD40 is too thin and would hurt your maf sensor Puma 110" SW
Post #36535 18th Jul 2010 7:42pm
Do they not come pre oiled ready for use?... Hence the sealed bag it's packed in?
Post #42850 17th Oct 2010 8:41pm
MK
sure! But you have to take it from the bag to use it Whistle Puma 110" SW
Post #42946 18th Oct 2010 5:27pm
So what your saying is the bag is more oiled than the filter Question Laughing
Post #42958 18th Oct 2010 6:34pm
K9F
That was beginning of July?
Has it sat in the bag at home for three and a half months? It's only a ten minute fit! Fit it and worry about the relube in a couple of years when and if it needs doing!
If need be i'll source some for you and/or enquire about shipping it to you if it's possible by boat! There must be some way of getting you some???
What about Opie can they not help you out or advise? PM them!
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #43122 20th Oct 2010 1:43pm
MK
ummmm I invite you to run an engine oil test. In my case I do not drive it on foggy&wet tarmac roads for going to the mall, so I have to be careful about the air filter issue. Puma 110" SW
Post #43123 20th Oct 2010 1:56pm
