Home > Td5 > MOT and EGR removal
Page 2 of 3 <123>
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
I have a TD5 10 engine and would like to fit a blanking EGR blanking kit. I have read it was possible to get one with an outlet to go to a boost gauge. As I progress through the mods and upgrades I want to do, a turbo gauge may be one of them so it seemed a good idea to go for a EGR kit with a take off. Trouble is the only ones I can find don't have this.
Any suggestions or recommendations? Thumbs Up Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #552523 31st Jul 2016 3:28am
Nick666
United Kingdom 1986 Defender 90 2.5 n/a Diesel SW Yellow
Going to sound like an idiot here, but can't you just put a t-junction in one of the hoses (like the one to the wastegate) and attach the gauge there? Should all be the same pressure after all...
Post #552546 31st Jul 2016 8:03am
grumpy old git
A quick search on the 'bay, no affiliation:
EGR Boost gauge kit
Post #552563 31st Jul 2016 9:07am
L90DNY
United Kingdom 2006 Defender 90 Td5 HT Corris Grey
Fitted that one above on mine, good quality bit of kit, all went on no trouble at all.
Post #552603 31st Jul 2016 2:47pm
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
That was all I did, works perfect Thumbs Up Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #552631 31st Jul 2016 4:34pm
MC84
Thanks for the feed back, looks like I know what to buy now Thumbs Up Thumbs Up Thumbs Up
Apart from fitting the unit, is that it, nothing else apart from drive?? Mike
Ford 100e 1959
Post #552661 31st Jul 2016 6:33pm
MC84
I ordered an EGR blanking unit with a turbo nipple from "EGR Delete" and it now on and running.
Although I have no affiliation with the Ebay seller I feel I'd like to mention they offer a super item with next day delivery. Instructions provided are clear and simple. What more could you ask for?
One thing I didn't think about, although I had some in the garage is gasket sealant for the mating surfaces. So remember to check you have some before you start!
I've included a link to the item I bought below.
http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...Sw2s1UzkuC Mike
Ford 100e 1959
Post #554503 8th Aug 2016 3:32pm
bogwert
Scotland 2003 Defender 90 Td5 CSW Zambezi Silver
How easy was it to fit?
Currently thinking of getting one for mine.
Post #569689 9th Oct 2016 4:39pm
MC84
About an hour all in I suppose. Really easy and a great product. Mike
Ford 100e 1959
Post #569777 9th Oct 2016 8:16pm
bogwert
Sweet, Cheers!
Post #569792 9th Oct 2016 9:11pm
Djcla
wondering about this mod , is it likely an issue now with all the new mot restrictions?
Post #766828 4th Apr 2019 12:07pm
Currently the situation is that your vehicle should fail if you have interfered with any of the factory-fitted emissions equipment, so a decat or EGR removal will be a failure. However it will only fail if the tester notices, and presently there are no emissions test run on diesels which are capable of detecting the removal or deletion of either the EGR or the cat. The tester is not allowed to remove covers etc as apart of the test, and may not be an expert on the particular vehicle, so there is a reasonable probability that your vehicle will pass simply because the tester can't see or doesn't notice.
There are however two other considerations which you may want to bear in mind.
Firstly, whether or not the MOT tester notices, to use a vehicle on the road which has the factory-fitted emissions interfered with is now illegal, so technically if you have removed a FF cat or EGR, or simply run a map with the EGR deleted you are committing an offence. It is an offence which is unlikely to be detected, though.
Secondly, if you are stopped for a VOSA check and your vehicle is decatted or has had the EGR removed, then it is overwhelmingly likely that this will be detected and you will get (a) a fine and (b) a prohibition notice. Whilst it is fairly unlikely that you will be stopped for a VOSA check if you use your Defender as a "Chelsea Tractor" type SUV, if you have the "working truck" look, and especially if you are towing a big IW trailer, then it becomes very likely that you will be pulled sooner or later. (If you have the trailer on the back, you'd better have a good answer to the tachograph question too)!
Post #766841 4th Apr 2019 12:54pm
Djcla
wow super info thank you very much , ill probably leave it
Post #766845 4th Apr 2019 1:18pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Blackwolf….that will get some bottoms twitching Rolling with laughter
Post #766854 4th Apr 2019 2:40pm
Maybe, but that is the way it is.
It seems inevitable to me that as the anti-diesel, anti-car, and general anti-fun movement gathers pace, those of us who don't wear hemp underwear, eat lentils, and drive ridiculously small electric cars that look like funfair refugees, will be subject to increasing scrutiny and face the kind of inquisition traditionally reserved for murderers and child-molesters*. I suspect that life will become increasingly difficult for people with decats and EGR-deletions.
*You have only to look at the constant flood of "Police Interceptors" type programmes on the box now to see that if you are stopped when speeding you are viewed in much the same way as a killer who's been apprehended on his way to commit a murder. We really seem to be losing all sense of proportion!
Post #766859 4th Apr 2019 3:07pm
Page 2 of 3 <123>
